| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#31 |
Dragging up an extremely old thread; is it worthwhile using NP0 type caps for bypassing op-amp supply rails, as opposed to more common ceramic caps like X7R? Is the difference only really shown in the audio signal path?
#32 |
I'd bypass them. The better ceramics clean up supply rail fluctuations better.
#33 |
the x7r are probably working just fine.
I can't see what advantage an NP0 could bring in local decoupling. |
#34 |
My understanding is that X7R caps are "lossy" and NP0 are not. The lossy quality of the X7R is what makes it good at suppressing noise.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja |
#35 |
Yes, that is my understanding too. The slight RF lossiness of the bigger ceramic caps means that parasitic impedances and resonances in PCB traces are not merely retuned (as an NP0 would do) but damped away. As always, use the appropriate cap for the job and ignore myths and fashions about 'good' and 'bad' audio caps.
#36 |
Thanks for the replies!
| ceramic capacitors .... | sakis | Solid State | 189 | 16th April 2009 07:26 PM |
| Flat round and old ceramic disc capacitors | AndrewGM | Parts | 1 | 6th October 2008 10:19 PM |
| what is the difference between silver mica capacitors and ceramic capacitors ?? | prorms | Solid State | 1 | 6th May 2008 12:38 PM |
| life lesson on ceramic capacitors in signal path | mazurek | Parts | 11 | 23rd February 2006 04:00 AM |
