| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
A while ago I bought a variac. As I need to fire it up I need your help. I’m trying to connect it so I can have 220V AC out from the variac.
This is what I believe: 1) Using a standard multimeters I should set it for min 220V AC (this one 600V). 2) On wire should be connected to ground 3) One wire should read 0 V AC if I measure between the wire and ground wire. 4) The other wire should read 220V if I measure between ground wire and this wire and between the above wire and this “hot” wire. Am I correct? |
#2 |
If this is your level of electronics knowledge, you are quite likely to blow something up or harm or kill yourself playing with high voltage. Please do much more reading on the subject!
but yes, that sounds right.
Jesus loves you. |
#3 |
Sorry for asking. I will be carefull in future asking questions.
#4 |
Never be sorry for asking...
You would be sorry if you killed yourself or burned your bench or house down, which is why I mentioned it.
Jesus loves you. |
| DIY Variac | Tyimo | Solid State | 4 | 6th October 2007 11:18 AM |
| FS 10A variac | woody | Swap Meet | 8 | 16th May 2007 04:38 AM |
| Variac | ben goh | Solid State | 21 | 12th March 2007 06:42 PM |
| Variac? | Scribble | Pass Labs | 16 | 29th July 2004 02:12 AM |
| Page generated in 0.06131 seconds (78.42% PHP - 21.58% MySQL) with 10 queries |
