Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 3rd April 2006, 04:32 PM   #1
elaar is offline elaar  United Kingdom
Default outboard power supply
Hi all,
I'm building a gainclone (my first attempt) and am using 2 toroidal transformers (1 for each channel), and am putting the power supply module in a seperate case, so that the main amp will fit in a nice small aluminium enclosure I already have.
My question is how exactly should I seperate this? Some people say that to keep EMI to a minimum I should place all AC components seperate (toroidals, main filter capacitors, rectifiers...) from the main amplifier components.
However, this would mean a long(ish) run of cable form the psu to the amp carrying DC which i believe is more susceptible to interference etc.. ALSO can't oscillation become a problem when chip-amps are quite a distance from the main power caps? or is this just with very high bandwidth buffer opamps?
With my limited knowledge I would have thought that putting the toroidals on their own would be the best bet with a small amount of AC components in the amp case so that the mains power caps are close to the chip-amp, but then what do i know Smile
Many thanks in advance
Andy
Old 3rd April 2006, 04:40 PM   #2
jackinnj's Avatar
if you carefully dress the leads in a power amplifier you won't pickup any a.c. from the mains -- the best way to check for a.c. is with a distortion analyzer -- looking for the distortion at the harmonics of the mains frequency.
if you must use separate cabinets use a FEMALE receptacle on the power supply, a MALE plug into the power supply -- put bypass capacitors on the power receptacle and at the point at which it enters the amplifier cabinet. when I had separated a solid state amplifier from its power supply I used a 3-conductor industrial extension cord cut to a convenient length.
the problem with long leads is that you waste energy as heat --
R * I^2 just like the electrical utilities -- better to put the amps into the music.
Old 3rd April 2006, 04:48 PM   #3
put the transformers and rectifiers and first stage smoothing in the remote PSU box.
Put second stage (high quality) caps beside/on top of the chipamp. These are effectively the decoupling caps that are normally on board.
The remote + decoupling form an RCRC PSU which can have less hum than a simpler RC supply.
The smoothing beside the rectifiers have a very high ripple so ensure you provide sufficient ripple capacity. Lots of small parallel caps can achieve this cheaply.
The local decoupling need low esr to enable the amp to source peak current and should preferably have more total capacitance than the first stage smoothing.
Hope this gets you started.
regards Andrew T.
Outboard power supply grounding ? woody Power Supplies 5 3rd May 2008 09:24 PM
Looking for Outboard Power Supply for B & K Sonata MC-101 Preamp dtm1962 Swap Meet 1 23rd January 2008 04:54 AM
DAC outboard from Ebay ttan98 Digital Source 0 22nd August 2007 02:24 AM
What cable for outboard supply ? (pics) redrabbit Power Supplies 6 31st March 2007 09:33 PM
FS: Aragon D2A MKII DAC with Outboard IPS Power Supply konstantin Swap Meet 0 17th July 2005 09:03 PM
Page generated in 0.07174 seconds (74.08% PHP - 25.92% MySQL) with 10 queries
