| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Do you know the chip: Analog SSM2404S
Do you know if we can use it at +-5.0v only? http://www.analog.com/en/prod/0%2C28...2404%2C00.html The spec specify 5.5v to 13v but... I've a dream. ;-) . |
#2 |
I'm using this for my preamp project, and the answer to your question is NO. I did some quick tests, and only one out of ten switch did work some times at 5V
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com |
#3 | |
It was to be sure. I love AD for that. Very nice when 5v and 15v are standard in most existing design. I plan to use a small PSU with LM7xL12 chips but as this is to replace an CD4053 inside an existing circuit, I'm not happy to add all these components... Another solution will be to use +15v and negative to ground but I'm not sure that solution will be good. Do you know if positive and negative pins need to be decoupled with a small caps? The datasheet is realy "basic". . |
| Quad SPST Analog Switch | RCruz | Solid State | 7 | 25th November 2008 12:07 PM |
| Best sounding analog switch IC for input source selector | rythmikaudio | Solid State | 10 | 28th February 2007 02:26 PM |
| spec sheet for tc9152 analog switch | ostie01 | Parts | 2 | 19th March 2006 10:34 PM |
| Analog Audio switch with 4053 | kmt | Analog Line Level | 19 | 21st February 2006 12:25 PM |
| Page generated in 0.07450 seconds (70.67% PHP - 29.33% MySQL) with 10 queries |
