| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I'm looking for a computer keyboard (PS/2) like the old kind with the rigid, crunchy keys. Specifically I want it to feel like a mechanical typewriter. The newer keyboards seem to use a different button mechanism and doesn't "crunch" and the keys don't feel solid. What would be a keyboard that is still available, that is PS/2 interface, that has crunchy buttons? No ergonomic keyboards please, looking for a standard keyboard layout.
Thanks everyone! |
#2 |
Hmmmm....
I've got a keyboard I bought in Japan. Mechanical switch type. QWERTY, but some of the symbols are in different places (quotes are shift+2). Cost me $50 (US equiv), asking the same +shipping. PS2 cable included (detachable; can be plugged in left or right side). Deep violet-blue base with black keys. Laptop type squished key placement. If you need a picture, I can pull it out of my closet and take one. Barely used it. Love the feel, but drove the wife and I nuts when we'd be emailing in the middle of the night. Clackety-clackety-clack... |
#3 |
Same, I stopped using mine because my wife complained. I know where you're coming from. I used to use a large and heavy keyboard I picked up at a fair for $1. It had a steel base, top and internal chassis.
#4 |
You are looking for an IBM Model: M keyboard. Infact, I'm using one right now. It's known as the "Clicky" keyboard. It's pretty much bulletproof, and they can still be found. If you can find someone tossing out an old 386-486 (etc.) you will probably find one of these keyboards. You can also look at Craigslist.com (in your particular area), or ebay. Good luck.
- Jim |
#5 |
Thanks for the IBM Model M suggestion. I will buy one and try it. Thanks a lot! I'll also consider taking bluesmoke's offer if it doesn't work out.
#6 |
No Prob. No Rush. Happy Hunting!
It waits silently in my closet for a master... |
#7 |
old Dell keyboards had that 'clickety' feel and sound too...
Si fractum non sit, noli id reficere! |
#8 |
The only problem with the model M is that some motherboards can't supply the required the current for them. Starting with the P4 generation notably Asus. Apparently there is some kind of mod that you can do to the keyboard. Some folks toss them out because they think it has gone bad. Then there is the noise.
I think the conguration is called the collapsing spring type. Right now I'm using a similar type of mechanism that is not as hard and crunchy nor as noisy as the IBM 's. It's a Fujitsu FK84700 Series and is a great alternative circa 1994. My M type is being stored away. Love the tactile feedback. |
#9 |
I love my old clicky! It clicks both when you press and then release. Makes it sound like you are typing fast! :-)
Poor stereo mix? Switch to mono! Perfect. |
| Korg PA2X Pro 76 Key Arranger Keyboard, Yamaha Motif XS8 88-Key Keyboard | holocoast | Vendor's Bazaar | 0 | 22nd August 2009 07:02 AM |
| 555 Keyboard | Growf911 | Instruments and Amps | 24 | 25th March 2009 05:39 AM |
| Keyboard mods | Prune | Everything Else | 0 | 29th May 2003 09:01 AM |
| KeyBoard Amplifier | IceRegent | Solid State | 0 | 20th September 2002 07:44 PM |
| Page generated in 0.08917 seconds (76.47% PHP - 23.53% MySQL) with 10 queries |
