| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I have acquired a very large toroid out of a Crown K2 amp and am trying to determine the output voltages when connected to 120v mains. I have a variable AC power supply so I thought I would bring the voltage up slowly and test the outputs. This doesnt seem to work as my power supply keeps popping it's 5 amp protection. I know you need soft start circuits on large toroids, isnt raising the voltage slowly simulating a soft start?
#2 |
It would need a soft start when there was a large filter cap connected somewhere after it. Are you using mains frequency AC? are you on the primary and is your secondary open circuit?
A primary is really a large inductor. If for some reason this is upsetting your ps, you might shunt your secondary with a resistance. I like to do initial winding testing with a signal generator (prefer that it can handle a short just in case) and a cro (a dmm will do). |
#3 |
Arghh, a K2 Arghhhhhh!
These have to be one of the least reliable amps I have ever worked with, and you've guessed it, one of the failure modes was the traffo secondaries shorting. I was given three dead ones, and the only things worth salvaging were the heatsink temperature sensors... If yours has this fault, sorry.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#4 |
Thanks Pinkmouse and Indm, shorted secondaries it is. The owner of the amp said it fell off his truck one night and never worked after that. I thought Crown was supposed to be such roadworthy gear? Oh well the heatsinks will look good on my chipamp and I bet the 6800uf caps will come in handy somewhere down the road. Actually I think I might use the old case for the chip amp, you know, make it look like I've got a real expensive amp!
#5 |
If it's any consolation, the Powerbase series are even worse.
| Seek help, the TA2022 / | ljm_ljm | Class D | 2 | 18th May 2009 04:01 PM |
| seek OB driver, circa 100-260 Hz | ro9397 | Multi-Way | 3 | 15th June 2007 02:52 PM |
| Seek the replacement of TA3137! | GPE | Solid State | 21 | 14th October 2006 04:03 AM |
| Trade a 40V 400VA Toroid for 20V 300VA Toroid | john65b | Swap Meet | 7 | 10th October 2006 03:49 AM |
| Page generated in 0.08295 seconds (71.05% PHP - 28.95% MySQL) with 10 queries |
