Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 28th March 2006, 02:09 AM   #1
KT is offline KT  United States
Default Ground Bus question
I'm building a preamp based on Dave Slagle's autoformer volume controls.
The preamp is passive, so there is no provision for power ground. Also, the chassis is plastic, so there is no need for chassis ground.
My question is, if I make a ground bus to connect all the RCA signal input and output grounds, would it be advantageous to make two separate ground rails, one exclusively for the left channel and one for the right channel, or would it be better to have one ground rail on which to connect all grounds?
My thinking is that by having separate ground rails for the left and right channels, that would eliminate one possible ground loop. But I really don't know too much about grounding schemes so any advice would be appreciated.
Thanks,
KT
TT ground Question Deacon_808 Analogue Source 3 29th September 2004 05:59 PM
GC PCB Ground Question Gcollier Chip Amps 0 18th June 2004 11:08 AM
Pin 7 to ground question for IGC Stever Chip Amps 6 8th November 2003 07:57 PM
does connecting mains ground with circuit ground create a ground loop? jarthel Everything Else 0 25th June 2003 12:55 PM
Page generated in 0.06532 seconds (79.54% PHP - 20.46% MySQL) with 10 queries
