i want to replace my wima caps in my valve amp is there better out there - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 15th November 2002, 08:51 AM   #1
Default i want to replace my wima caps in my valve amp is there better out there
if i replace my wima caps in my valve amp for hovland or any other type of polypropaleane cap's will they improve the sound they are all round my valves . can any one please explain how thses caps work thanks for your time
Old 15th November 2002, 09:26 AM   #2
halojoy is offline halojoy  Sweden
On Hiatus
Default Re: i want to replace my wima caps in my valve amp is there better out there
WIMA and RIFA have very good caps.
WIMA have some different Polypropylene caps,
some are slightly better than another, but will cost more.
If you want a good MKP (metallized PP) cap for Audio.
Use SOLEN SCR axial cap. Reasonable prize /uFxVolt. (money/CV)
(sorry, did not find some pictues of SOLEN Axial Caps)
Old 15th November 2002, 09:41 AM   #3
On Hiatus
SOLEN SCR MKP capacitors
Old 15th November 2002, 10:39 AM   #4
Circlotron's Avatar
Default Hearsay only.
I havent tried them myself, but have read that FKP type caps. i.e. polypropylene and foil WIMA caps are the way to go if you don't want to go way esoteric and expensive. They are the light blue ones with yellow epoxy fill. They make no claims for audio usage but are a rock solid no-nonsense cap for high frequency, high current and pulse usage. Many other caps used in such a way get all hot and bothered.
Exactly what caps are you using now? If you are already using FKP1's then you are probably about to pass that point in the money vs. results graph that takes a sharp bend for the worse.
GP.
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/multi...tml#post353269
Old 15th November 2002, 10:49 AM   #5
Banned
Send a message via Yahoo to Elso Kwak
Lightbulb WIME Caps
Hi circlotron,
I found the red coloured Wima MKP 10 better sounding.
Old 15th November 2002, 11:03 AM   #6
Electrons are yellow and more is better!
peranders's Avatar
I have a Electronic Concept cap in my hand! It feels as good as it is. EC makes the best(?) caps in the world. They can be seen in heavy duty switched power supplies.
Check out how much current they withstand!
http://www.eci-capacitors.com/
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
Old 15th November 2002, 11:27 AM   #7
diyAudio Senior Member
fdegrove's Avatar
Default CAPS
Assuming that's Newcastle in the U.K. i can highly recommend the ICEL range of polyprops as used by some major tubeamp manufactures.
I noticed RS Components sells them.
For the more esoteric caps and parts you could check out this US supplier,they have some on sale with a 30% discount:
PCX
Ciao,
Frank
Old 15th November 2002, 12:25 PM   #8
peranders's Avatar
if i replace my wima caps in my valve amp.....will they improve the sound they are all round my valves .
Not really knowing but my hunch is no. The major constribution in the sound are the tubes and the transformer, I think.
Nelson Pass discussed this in an another thread and I believe his is right.
Capacitor Distortion
Old 15th November 2002, 12:30 PM   #9
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
You don't have to replace all of them at once. Just try the coupling ones first and hear the results. From my experience good caps make a difference. And Hovlands are a pretty good choice.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 15th November 2002, 12:57 PM   #10
peranders's Avatar
It's a shame that I don't have the camera here. The legs are 1 mm thick!
Check the data for 5MP12!
New 10u/16V WIMA film caps jackinnj Parts 37 10th December 2010 10:07 AM
Wima MKA caps Calamaro Parts 0 6th April 2009 10:11 AM
FS BB OPA660AP, WIMA caps, ROE Caps and other Andypairo Swap Meet 10 13th August 2005 02:46 AM
Wima film caps zerodigit Parts 2 31st October 2003 12:24 AM
Wima MKP 10 caps Ilianh Swap Meet 5 12th March 2003 09:29 PM
Copyright ©1999-2017 diyAudio
