| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Came across this, it has a single value written on the case but has three leads (had to fix the scan).
I'd like to know what it is if anyone knows? |
#2 |
Banned
just look at the site of Jensen
#3 |
I've looked at dozens of sites including Jensencapacitors, but no info on these.
#4 |
From the value it looks like a motor starter capacitor, or something similar?. If you check the connections I'm presuming either two of them will be connected together, or one won't be connected at all - the three connections are used just for mechanical stability when mounted.
Nigel Goodwin |
#5 |
Hmm, plausible. BTW the case is 1 5/8" long. My research tells me so far that other mixed dielectric caps are paper and polypropylene.
#6 |
Banned
#7 |
that may be a dual capacitor with two sections and a common negative or ground connection....
#8 | |
| Unusual TT. | G | Analogue Source | 3 | 10th February 2008 10:26 PM |
| Unusual Driver | ShinOBIWAN | Multi-Way | 4 | 8th November 2005 01:14 PM |
| **** another unusual hum problem !! | Shoog | Tubes / Valves | 15 | 1st January 2005 03:49 PM |
| Unusual | BJ Johnson | Solid State | 2 | 13th May 2003 06:08 PM |
| Page generated in 0.10343 seconds (78.34% PHP - 21.66% MySQL) with 11 queries |
