| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Does anyone know where I can get polarised 1uf Caps from?
Ideally they need to be X7R 0805's Is there such a thing? Thanks Lee |
#2 |
Hi Lee,
Sounds like a Ceramic cap with a XR7 characteristic. They should be available but maybe not everywhere. http://www.ttieurope.com/microsites/...w/products.cfm This is one supplier. -Chris |
#3 | |
I do have some XR7 ceramics but I've absolutely no idea if they are polarised or how the heck you would know which end was which, no markings at all! Looks like a good Google session.......... Cheers Lee |
#4 | |
Hi Lee,
Well, my point was that they were non-polar. A polarised ceramic cap makes no sense what so ever. Quote:
-Chris |
#5 |
Polarised 1uF SMD means either tantalum or alumimium. A 1uF tantalum is pretty small.
X7R is a ceramic dielectric type and is never polarised. Most 1uF ceramic will be Z5U or similar, which is really horrible for audio. You can get 1uF X7R, but will be fairly large and expensive. Even X7R is not that good on voltage coefficient, dielctric absorbtion etc. |
#6 | |
I've noticed on a tripath parts list that this is a ceramic X5R??? Are they contradicting themselves? |
#7 |
Hi Lee,
I suspect they meant a polarized type for the charge pump and ceramics for bypass. A poly cap for the charge pump would work even better. The fact that it is non polarized will have no effect on the circuit. They must mean X5R as X7R does not reach 1 uF. Time to e-mail them to clarify. -Chris |
#9 |
the polarised looks like they intended an SMD electrolytic or tantalum for the charge pump connections. If there is room then a change to a small footprint metalised film could help performance.
regards Andrew T. |
#10 | |
They seem to be 4mm dia at the smallest but that would fit. Cheers Lee |
| Replacing electroytics in signal path with non-polarised - which type of caps to use? | jpcoetzee | Solid State | 13 | 15th May 2008 01:12 PM |
| Replacing multi-section caps with multiple caps? | Sir Trefor | Tubes / Valves | 1 | 29th May 2007 10:17 PM |
| non polarised cap replacement | lt cdr data | Parts | 13 | 26th November 2006 10:31 PM |
| Doubt on plarised cap vs non polarised | rs1026 | Chip Amps | 4 | 17th September 2004 06:15 PM |
| Replacing ceramic disc caps with silver mica caps? | G | Solid State | 5 | 18th November 2002 01:02 PM |
| Page generated in 0.10518 seconds (77.31% PHP - 22.69% MySQL) with 12 queries |
