| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hi.
I need a opamp that can be used with a single supply up to 50-60V and deliver up to 1A at DC. I can't see any reason why the LM3886 couldn't be used, but as it is a "audio-amp" I might have overlooked something? Any other suggestions? I need to be able to control the output to within 1mV DC over the entire 50V range... Is that possible? Regards TroelsM
Need more time... |
#2 |
The LM3886 is not unity gain stable, the minimum is ~20dB
There is no real difference between a power opamp and an audio amplifier. The dc input performance is not as good, but you can usually work round this. |
#3 |
Hi.
Thanks for your answer. Could you be more specific about the "DC input performance" ? Any other ideas, other opamp better suited for this application? Regards TroelsM
Need more time... |
#5 |
It's pretty simple ( or is it...)
I need to control a voltage between 0 and 50V with an accuracy of 1mV... The input/control is either a digital signal og an analog signal. I was thinking of using the LM3886 as an non-inverting amplifier amplifying from 0-5V til 0-50V (or 0-2V to 0-50V). The output-current is under 100mA, but I would like an option for higher currents. If there's no power-opamp that can do this I might have to make one myself. Any Ideas on how to do this? After all DC is not very "audio-like" and I'm not sure that an audio-amp would be the best option. Regards TroelsM
Need more time... |
#6 |
The OPA 541/8/9 will be more suitable, have a look at the datasheets, however getting that accuracy of output will not be so straightforward. Why do you need so much accuracy?
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#7 |
I'm designing a piece of test-equipment and I have en spec that states that the output us to be know within 1mV.
I know it's not a trivial matter, and in the end I might have to go with a lower precision. I'll have a look at that OPA54X. Regards TroelsM
Need more time... |
#8 |
The OPA541 seems to be perfect! Even comes with an apl. note that fits my purpose perfectly.
Thanks a lot! Regards TroelsM
Need more time... |
#9 | |
#10 |
Well, where are actually not sure on that :-)
There will be a 16-bit measuring of the actual voltage, but I would still like to be able to set it with an accuracy of 1mV.. But I see your point. Regards TroelsM
Need more time... |
| My First LM3886 GC | samsagaz | Chip Amps | 49 | 29th June 2008 07:55 PM |
| Psu Lm3886 | Mayday | Chip Amps | 29 | 29th April 2007 06:10 PM |
| Lm3886 Bpa | Tombson | Chip Amps | 99 | 21st August 2006 12:04 PM |
| Are two separate lm3886 = 2*lm3886 in parallel or bridge mode | rs1026 | Chip Amps | 11 | 21st October 2004 10:24 AM |
| Page generated in 0.09912 seconds (82.17% PHP - 17.83% MySQL) with 10 queries |
