Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 14th November 2002, 01:55 PM   #1
Bricolo is offline Bricolo  France
Bricolo's Avatar
Default Need some help with PSU Designer II
How can I put 2 capacities in parallel?
I always get an error message when I try to do this
thx
Old 14th November 2002, 02:18 PM   #2
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
I don't think you can, but...
You can just add the values and apply the total to the capacitor in circuit.
Or, add an LC or RC filter, making R or L so small as to have negligable effect.
Old 14th November 2002, 02:28 PM   #3
Bas Horneman's Avatar
You're right John..
one just can't do it..so you can't see the effect of a bypass cap etc..it is pointless anyway trying to detect that in psu designer..I just use it for ballpark figures..
Only a good scope or a good set of ears can determine that effect..
I hope you have a good scope John, otherwise you're lost ;-)
Old 14th November 2002, 02:52 PM   #4
Bricolo's Avatar
ok
since 2 smaller caps are discharging faster than a single big one (that has the same cap), it would be cool to put 2 caps in //
another question: how can I mesure my caps, selfs, and transformer resistance?
Old 14th November 2002, 02:57 PM   #5
The transformer you can just measure the resistance with your multimeter...
Don't know bout the rest..
Old 14th November 2002, 03:31 PM   #6
Bricolo's Avatar
OK
i'll measure this when i'll be able to find the transformer...
Old 14th November 2002, 03:36 PM   #7
roddyama's Avatar
Hi Bricolo,
WRT the measuring the capacitor equivalent series resistance, take a look at this article by Walter G. Jung and Richard Marsh
from Audio Mag.http://www.capacitors.com/pickcap/pickcap.htm#signal
You'll also need a frequency generator. Dialetric absobtion requires a little more circuitry.
Rodd Yamashita
Old 14th November 2002, 04:44 PM   #8
Bricolo's Avatar
I've measured 53 Ohm for the primary (230V) and 1 Ohm (!!!) for the secondary (12V)
Is this possible??
Old 14th November 2002, 05:23 PM   #9
dhaen's Avatar
Bas said:
Tektronix TDS210:
http://www.tek.com/Measurement/cgi-bin/framed.pl?Document=http://www.tek.com/Measurement/Products/catalog/tds200/eng/specs.html&FrameSet=mbd
Only 60 MHz, samples at 1GHz, but fine for audio, and slow logic.
Can only justify the cost because I also use it to earn money!
Used to have a used Tek 453, lovely scope but too heavy.
Old 14th November 2002, 05:25 PM   #10
dhaen's Avatar
Bricolo wrote:
Yes, absolutely typical.
The lower the DC resistance, the better.
Calling X-over designer ttan98 Multi-Way 12 13th February 2008 11:08 PM
Is PSU Designer II correct? zxx123 Tubes / Valves 7 20th January 2008 05:21 PM
[b]pcb Designer Wanted [/b] sakis Solid State 6 18th December 2007 11:57 PM
Hello, from amp designer rmetz Introductions 2 29th January 2002 07:18 PM
Page generated in 0.11700 seconds (81.62% PHP - 18.38% MySQL) with 10 queries
