| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I am in the process of replaceing the Caps in my ageing Sansui UA-117II integrated amp (has to be about 30 years old, and bass got very thin).
The inside of the amp is quite well done and way above constructin standards I see today. Even the PCB traces are printed on the top to make things easy. My question is; I noticed some of the caps on the amp are eletrolytics, but appear to sit right in the audio path. Also on the circuit diagram they are not marked as polar, but on the PCB, they are. Can I safely replace these with film caps? |
#2 |
diyAudio Moderator Emeritus
Yes, you can. MKP are a fine choice at that spot. When they physically do not fit you can use MKT/polyester caps. Wima MKS2 are available in 5 mm pitch and they sound OK.
It's only audio |
#3 |
Many thanks.
#4 |
For coupling capacitors, the Dynamicap is the best I have found.
They are very expensive, however, and you may not want to spend that much money. They also are only available up to a few microfarads, and you may need larger values, which forces you to use electrolytic caps. The best source i have found is parts connexion in canada; they have just about all of the audiophile-grade caps in stock and good info on applications in most cases. |
| FS: computer grade electrolytics & polyprop caps | len_scanlan | Swap Meet | 6 | 31st October 2006 05:15 PM |
| Any reason not to change Tantalum caps for aluminium electrolytics | Puggie | Parts | 14 | 6th December 2005 01:15 PM |
| Chinese foil caps? | aarsoe | Parts | 12 | 18th March 2005 09:23 AM |
| Advantage of tin foil caps ? | Bernhard | Parts | 3 | 5th March 2004 06:39 AM |
| Multisection Can Caps Vs. Individual Electrolytics | DocJDG | Tubes / Valves | 4 | 14th January 2002 12:40 PM |
| Page generated in 0.06638 seconds (71.41% PHP - 28.59% MySQL) with 11 queries |
