Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Black Gate 'super E' caps
Old 21st July 2004, 12:25 AM   #91
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Black Gate 'super E' caps Send a message via AIM to Peter Daniel
I've heard today that Jensen is closing down, is that true?
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 21st July 2004, 01:02 AM   #92
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
I don't think so...and certainly hope that rumour is false.
Frank
Old 21st July 2004, 05:25 AM   #93
Sunsun22 is offline Sunsun22  Hong Kong
Sunsun22's Avatar
Peter, thank you for your info again.
Do you have a pic of the sensing coil?
Can you draw a diagram on how to hook up everything to test the inner and outer foil?
In the thread - Skinned electrolytic caps (in loving memory of Fred D.) ,
http://www.diyaudio.com/forums/showthread.php?s=&threadid=35471&highlight=inner+o uter+foil
, what will happen if the DTU has a plastic cap like the Vishay/ROE that you are using?
Sunny
Old 10th September 2004, 04:00 PM   #94
mieze245 is offline mieze245  United States
Send a message via AIM to mieze245
Question Super e cap config
Just a quick question and please forgive my ignorance.
when using the super E config this will double capacitance.
now does this allow double the voltage?
also lets say you have an orginal value of 10uf (output coupling) and when super e config used it is 20uf is all of this acceptable
or is the idea to use 2 caps to equal what ever the orginal value is supposed to be.
Old 10th September 2004, 04:22 PM   #95
Bas Horneman is offline Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Nope..it will halve the capacitance.
I think so.
Depends on other parameters such as the load that the next stage presents to it.
But 10uF + 10uF in series will provide an effective capacitance of 5uF
If you can see the speaker cone move...it's not hifi.
Old 10th September 2004, 08:50 PM   #96
fdegrove's Avatar
It does for caps put in anti-series, back to back if you like....
It would be advisable to put voltage equalizing resistors across each cap in case you intend to surpass the nominal insulation voltage of the individual caps.
Doing so will make sure that neither of the caps sees excessive voltage.
From what I see this is not what Jelmax had in mind but I don't see why you couldn't. After all they're caps.
In the most common Super E configuration however, the caps are NOT put in series but put in anti-parallel to each other.
In this case the total capacitance doubles but the allowable voltage remains the same.
For further info:
SUPER E
Frank
Old 9th July 2005, 07:38 PM   #97
Sebastiaan is offline Sebastiaan  Netherlands
Default Parallel
Dear,
2 Blackgate N in super E cap. config act like one (almost) ideal condensator right? What happen if you build a powersupply with (for example) 20 blackgate N elco's. Every pair is in super E cap. And you put al the pairs parallel. What would be the result's?
Kind Regards,
Bas
Old 9th July 2005, 07:42 PM   #98
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Default Re: Parallel
A very empty wallet.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 9th July 2005, 11:09 PM   #99
Default Re: Re: Parallel
Dear Pinkmouse,
You are right The prices are not wallet friendly . But let's assume you get a result that's not from this world. No one tried it before. I strongly believe the ultimate sound is only reachable with the best powersupply. My pre-amp already had discrete voltage regulator's. wich are so silent.
I stille hope someone can answer my question. Is it possible to put so many pairs in parallel, or is the E cap only usable as one single pair?
I saw pics of the huge Krell MRA, with a big bank of BG's but I think it are FK's en not N or NX.
Kind regards,
Bas
Old 7th September 2005, 02:26 AM   #100
fdegrove's Avatar
There's no technical reason why you wouldn't be able to put n caps in // in E-config.
One good reason, besides the exorbitant cost, not to go down that road is that the upshot would probably be offset by the stray inductance of the capacitor bank.
Ciao,
Frank
Black Gate 'super E' capsHide this!Advertise here!
WTB:Black Gate Caps Fast996 Swap Meet 2 11th November 2008 06:45 AM
Black Gate Caps - end of the road Nuuk Parts 7 7th September 2004 12:41 AM
Asc/Angela vs Black Gate caps hardcore Parts 9 24th July 2003 07:38 AM
Copyright ©1999-2017 diyAudio
