Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 10th March 2006, 09:09 PM   #1
neil_kaye's Avatar
Default Resistors and soft starts
Newbie question here:
I have a class D amplifier that is powered by a 12.4 volt SMPS power supply. The amplifier requires a soft start to avoid a turn on pop as the capacitors charge up. The manufacturer of the amp (DIY paradise) has a recommended soft startup which is placing a 240ohm 1/2w resistor in a switch posisiton 2 (where 1 is off and 3 is on). Letting the trickle voltage run in for a few seconds and then switch to on.
I am tearing my ahir out trying to reolve this. Here is my problem:
1. The switch position 2 (with resistor) measure a full 12.4 volts across its poles. Postion 1 shows 0 volts whilts postition 3 shows 12.4 volts.
2. The resistor I belive is on the correct location becuase i if i severe it, the voltage drops to zero.
My questions are:
1. Help!!!!! please
2. What voltage should i be reading across the resistor?
3. Is there anything wierd above teh smps supply that would require a different type of resisor?
As part of the troubleshooting i have been going through, i added a LED in series with the resistor and voltage dropped to 10.2V across the poles at posisiton 2. So clearly adding something here is affecting the voltage. I just don't know what to add in hte posistion - resistor wise to get the right volatge to allow for soft start.
Old 14th March 2006, 08:58 AM   #2
Resistor is to be connected between 2 and 3 and supply is taken from 3.
This way when the switch is in position 2, it will be in series and wiil be out of ckt when switch goes to 3
Gajanan Phadte
The build starts. (DIY Turntable) kilowattski Analogue Source 19 20th May 2008 12:31 PM
Aleph P1.7 "the design starts here" Stefanoo Pass Labs 51 5th March 2007 12:52 PM
LM3875 GC Starts Today......i think cwoodall Chip Amps 3 10th September 2005 05:20 PM
Soft start & Soft Switch circuit: can anybody help? m.parigi Solid State 95 22nd August 2005 03:32 PM
Page generated in 0.06849 seconds (79.97% PHP - 20.03% MySQL) with 10 queries
