Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 8th March 2006, 03:12 PM   #1
traw is offline traw  United States
Default Trimming a power supply
Have some honking 30volt tranformers, used as a pair would give me 42.x volts rectified. But, I would rather be below 40 volts. Given mass of them would say they are around 600-1000va each.
Question about 2 approaches and looking for better solution.
1 - use 3-4 heavy duty diodes ->| ->| on positive rail and biased matching number of diodes biased in other direction of negative rail doing it after rectifier and before the caps. Would that work?
2 - what's a simple transitor assisted approach? like have seen transitor aiding a 78xx/79xx voltage regulator, for current boost.
should I be looking zener ? or am I just burning power squeezing transformer into a different design (figured, "...i just need to drop a few volts"). Extra transformer, like variac or step down of some sort out of question...
Old 8th March 2006, 03:24 PM   #2
BobEllis's Avatar
What is the end application? Class A or other?
How about unwinding a few turns of the secondary until you get the voltage you want? That way you won't be wasting energy heating the room.
Don't forget the output voltage will drop under load. Your theoretical 42 volts does not seem to include diode drops. If you have independent secondaries you can use a bridge for each and drop 1.2 volts.
Old 8th March 2006, 03:35 PM   #3
thought about holding onto, or leave be, until i get around to doing a classA...
was thinkinopg about using for bpa200 (bridge-par 225wpc) gainclone. I believe the abolute max supply voltage rating for 3886 chips is 42 volt per rail, or as stated in datasheet 84V differential. But worried that if I pass this amp on (inevitable in DIY), that someone else would have a volt or two extra on their household voltage pushing it over the limit. Plus want to avoid tripping chip protection circuits.
Old 8th March 2006, 03:50 PM   #4
BobEllis's Avatar
You're going to be way over the limit for chip amps. They won't load it much at idle, so assuming 5% regulation and 5% line overvoltage (common) you are over 46 volt rails.
Better to save those transformers for another project if you don't want to unwind it a bit or use a regulator. See the chipamp forum for a few threads on regulated supply gainclones.
Old 8th March 2006, 06:05 PM   #5
Yeah... that's what I was kind of figuring.
Old 8th March 2006, 06:50 PM   #6
Electrons are yellow and more is better!
peranders's Avatar
30 VAC will probably do without any problems. You are just at the limit but not way over it.
/Per-Anders (my first name) or P-A as my friends call me
Old 8th March 2006, 06:59 PM   #7
BobEllis's Avatar
P-A -
If the line voltage is 10% high like it frequently is here in the states and the lightly loaded voltage is 5% higher than rated (fairly typical for big toriods) he's fried his amp. Too close to the rated maximum for my comfort, but everyone has their own limits.
And those transformers sound like they ought to go into something more interesting than a BPA200 chip amp (wayyy overkill) How about an aleph 2?
Bob
Old 8th March 2006, 07:27 PM   #8
macboy is offline macboy  Canada
Use a "capacitor multiplier", which is sort of like a regulator, except that it isn't. It's really an active ripple filter. It works by using a transistor to drop a few volts from the rail voltage, and that transistor is driven in such a way as to attempt to stabilise the output voltage as much as it can, given the amount of dropout that it works with. Not only will you bring your voltage into line for your gainclones, but you will also have a cleaner supply (less ripple anyway). Have a look at Rod Elliot's project number 15
Old 8th March 2006, 07:40 PM   #9
Bazukaz is offline Bazukaz  Lithuania
Send a message via ICQ to Bazukaz
For a BPA-200 , to drive an 4 Ohm load , you would need around +-30V rails.
Assume each channel has a max. power consumption of 500W(output +dissipation).
So , around 10 volts must be dropped.That is (40/30)*500 = 125W of additional power dissipation in regulators for each channel ! This goes for a larger heat sink.
I would better unwind some windings.
Lukas.
Old 8th March 2006, 07:46 PM   #10
Sorry for errors in equation , should be (10/40)*500 = 125W.
'Trimming' phono-pre's output with pot/attenuator Aleksunder Solid State 12 1st September 2006 04:47 PM
Trimming ganged potentiometers with... trimpots? RHosch Parts 1 18th February 2005 10:46 PM
Trimming resistors Jarno Solid State 5 14th February 2004 07:24 PM
Zen trimming pots a big no no ?? Shoog Pass Labs 7 30th January 2003 06:24 PM
Page generated in 0.09488 seconds (80.88% PHP - 19.12% MySQL) with 10 queries
