Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 5th March 2006, 02:29 AM   #1
xplod1236's Avatar
Send a message via AIM to xplod1236
Default 1800 W power inverter
I'm looking for something that will put out 15 amps at 120v continuously to run some power tools. I looked thru the PE catalog and found this. The price is really good, but how is the quality? Can anyone recommend a good quality, reasonably priced inverter?
Old 5th March 2006, 02:53 AM   #2
Send a message via AIM to DigitalJunkie
It should be okay. Be sure it has enough surge capacity to start your saws/drills,etc.. (motors draw a huge surge when starting from a stopped position,or if you hit a nail,etc.)
Be sure your 12V supply is 'Beefy' enough!
You'll need large power cables too. 15A @ 120V = 150A @ 12V.
(plus a bit more for losses. maybe 10% ?) so say 165A @ 12V
Try to use the fattest,shortest cable to the battery/power supply that you can. That's alotta juice!
You could drain an average car battery fairly quickly at that rate,but that assumes the full 150+A continous load.. You may not always be drawing that much power,and not continously either,just while you're using the tools for sawing/drilling/etc.
Maybe a small continous load for lights,and other gizmos..(cordless tool chargers,etc.)
Be sure the vehicles battery/charging system is 'up to snuff' if you're installing this in a car.You may want/need to upgrade to a high-output alternator,and a large capacity (deep cycle) battery (or 2!). You could run down the 'stock' battery quickly,and smoke the alternator with that kinda load.
Old 5th March 2006, 03:18 AM   #3
xplod1236's Avatar
You read my mind. That's exactly what I was thinking.
It should be okay.
According to the specs, it should be okay, but does its low price mean low quality? How reliable is this? Does anyone have comments/experiences with this product?
Old 5th March 2006, 06:58 AM   #4
rcavictim's Avatar
I have some of the 1000 watt Xantrex modified sine inverters that are that style and they are just fine. Put a second HD battery in your vehicle. Use #1/0 wire or heavier between them. Do not pull inverter negative rail power through the vehicle chassis. That 2500 watt unit will actually damage a single car battery with what it can draw. That would be assault and battery. You never hear about assault and two batteries! Think about it. Ha ha.
I.Q.Test. Have you ever purchased a recreational snowmobile?
Heathkit AA-1800 Stereo Power Amplifier Sithlord2007 Solid State 37 5th May 2011 03:37 AM
Power Inverter help lljohnll Power Supplies 14 16th December 2009 05:44 AM
power inverter rtill Everything Else 1 27th February 2009 11:15 AM
power inverter Kelloggrice Parts 1 8th June 2007 07:44 PM
Page generated in 0.07948 seconds (76.82% PHP - 23.18% MySQL) with 10 queries
