Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 4th March 2006, 01:57 PM   #1
spotnie is offline spotnie  Netherlands
Default Prehistoric Opamps
I am looking for similar replacements for the following parts:
* M5207L01 - Voltage Dependent Opamp
* M5281AL - Opamp
* M5216AL - Opamp
Parts belong to this guitar effect: Here
I've seached google, a few webshops (Farnell, Conrad, Digikey), this forum, some books, but none of them had those or links to any replacements.
Could someone help me, or atleast point me in the right direction?
Thanks in advance!
Old 4th March 2006, 04:24 PM   #2
poobah is offline poobah  United States
poobah's Avatar
I have good luck with places like this
These are services that list excess inventory that is sitting on a manufacturers (not distributers) shelf. They act as an intermediary... broker of sorts.
I do not know how well it all works if you only need a few parts though... I have only used these services before when I needed large quantities of parts that were back ordered or otherwise unavailable.
Good luck,
Old 19th May 2007, 07:31 AM   #3
Senso is offline Senso  Netherlands
You could check my site and be pleasantly surprised:
http://www.vintageplanet.nl
Senso
Old 21st May 2007, 08:53 PM   #4
The op amps look like standard 8-pin dual pinout (other than the + supply pin being mislabeled as "3" instead of 8). You could probably use any of a number of chips in there. Only IC2A is in the audio signal path, and IC2B to generate a virtual ground... the others are used to generate and/or manipulate the VCA control voltage, at frequencies well below the audio band, so almost any crummy low-voltage dual op amp will work fine for IC3 and IC4.
The M5207L01 VCA would be hard to substitute. Good luck in your search.
FS: Opamps Charlez Swap Meet 2 17th August 2008 10:45 AM
JRC opamps browser Solid State 3 30th July 2008 08:58 AM
FS/WTT: Opamps seiko_citizen Swap Meet 0 20th October 2006 09:23 AM
OPamps xaudiox Swap Meet 2 31st August 2006 02:40 AM
FS: Power Chip OpAmps and other OpAmps & D to A Converter dtm1962 Swap Meet 4 12th January 2006 10:07 PM
Page generated in 0.06815 seconds (72.47% PHP - 27.53% MySQL) with 10 queries
