Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 1st March 2006, 02:47 PM   #1
Default soldering iron
Is the Black & Decker dual- temp craft and soldering iron any good?
One thing it has different tips, some of them might be good for smd components.
Does anyone have experience with these iron?
Old 1st March 2006, 03:28 PM   #2
hifimaker's Avatar
You might consider looking at the Weller wes51. They are under $100, have a wide range of temp control, and you can get a huge variety of tips for under $5 bucks. I use the standard tip that came with the iron and bought a needle point tip for smd's. It's also ESD safe.
Works awesome and they have a great reputation.
Sorry no personal experience with B&D models, I did not realize they made soldering irons.
-David
Old 1st March 2006, 04:16 PM   #3
-David
Thanks for the reply
I might buy the weller in the future but the Black & Decker is $20 at Homedepot.
It has odd tips even one shaped like a leaf
Old 1st March 2006, 06:17 PM   #4
Brian Donaldson's Avatar
$20 soldering irons will give less than $20 results. Black and Deckers tool quality has really fallen off in the last 5 years. If you really can't spend more than $20, Then get Ungar with interchangable elements and tips or watch out for a deal on a used station. Once you've used a temp controlled quality Iron, you'll never go back.
Old 2nd March 2006, 11:07 AM   #5
Glowbug is offline Glowbug  United States
Glowbug's Avatar
If there's even a remote chance you're going to be doing SMD work, you want the best quality tools you can afford
Hell, surface mount is damn annoying even with the proper tools
Jim J.
Old 2nd March 2006, 11:21 AM   #6
BobEllis's Avatar
I have a CSI station 1A http://www.web-tronics.com/solstat.html
Although I have never used a real quality soldering station, this does the job for me, even with SMDs. Worlds better than the cheapie blister pack irons. $50 with a bunch of tips.
Old 3rd March 2006, 01:29 AM   #7
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
I've got the CSI 2A and it's comparable to a Weller station which I use daily at work - only it's a lot cheaper! I build and rework boards that use all surface mount parts. 0603 size and up packages are easily soldered with normal or flat/chisel type tips and some sort of flux (liquid or pen dispensed). Either of the CSI stations are great for the price. The tips don't seem quite as good as Wellers but that just means you have to do a little more work to keep it clean.
Brian
Old 5th March 2006, 02:20 AM   #8
anatech is offline anatech  Canada
anatech's Avatar
Don't touch the B&D iron.
For most PCB work, you need a ground referenced tip, not a hard ground. You also will need a controlled tip temperature.
There are many good controlled stations for $100 or less. Not getting one of these will cost you more $$$ in so many ways.
-Chris
Old 5th March 2006, 04:54 AM   #9
Nordic is offline Nordic  South Africa
Nordic's Avatar
SOmeone in of of the trade threads said he was sitting on a few nice soldering stations and irons only needing tips for $40 or somethiing... looks like a bargain
Old 7th March 2006, 10:03 PM   #10
dfdye is offline dfdye  United States
dfdye's Avatar
Well, I hope you guys are right about the CSI irons. I just picked up one of the 1A models and am keeping my fingers crossed!
David
looking for a soldering iron Shpoop Parts 38 8th September 2008 02:58 AM
42 VAC soldering iron Jan Dupont Parts 2 8th August 2008 03:48 PM
For those of you in the UK who need a new soldering iron 5th element Parts 2 26th March 2004 10:58 AM
What soldering Iron? sleepy Everything Else 27 23rd October 2002 10:37 AM
Page generated in 0.09351 seconds (79.69% PHP - 20.31% MySQL) with 10 queries
