Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 19th February 2006, 11:05 PM   #1
rv1890 is offline rv1890  Armenia
Default double sided copper clad
If im building a crossover for my loudspeakers is it ok to mount the components on a double sided copper clad board??. The components are a couple caps, resistors, and steel and air inductors. Does the copper clad board present a problem of any sort??.....Also, since im using a common ground point, is it ok to mount a small nut and bolt in the middle of the copper clad board and ground all the components there??. Does that present a problem??... Thanks guys.........if you have any advise on other good boards to use then please let me know. Are there any advantages to using different kinds of boards??. thanks
Old 19th February 2006, 11:09 PM   #2
pinkmouse's Avatar
I wouldn't worry about copper clad board. I either glue the components to a small piece of thin MDF or ply, or used perfboard, PCB substrate drilled with rows of holes, but no copper.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 19th February 2006, 11:20 PM   #3
so thats a yes??....its ok to use it and mount the grounds on the bolt at the central location?
Old 19th February 2006, 11:30 PM   #4
pinkmouse's Avatar
Well, if you really want to, yes. But there are cheaper methods. Are you going to etch the PCB, or use it as a ground plane. Either way, you don't really need double sided.
Al
homemade double-sided PCB cb951303 Parts 22 4th April 2006 11:57 PM
Double Sided PCBoards cm961 Parts 3 21st November 2003 04:45 PM
Large Sheets Of Copper Clad Board. bigparsnip Swap Meet 0 9th July 2003 12:21 PM
Double Sided PCB Req in the UK Rarkov Everything Else 0 10th March 2003 03:25 PM
double sided pcbs Opie Parts 3 31st March 2002 05:22 PM
Page generated in 0.07151 seconds (72.72% PHP - 27.28% MySQL) with 10 queries
