Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 17th February 2006, 09:33 PM   #1
Question How to remove thru-hole IC from multi-layer PCB?
Greetings to all!
I need to safely remove a through-hole DIP IC from an old ISA soundcard. See the picture. The board doesn´t matter and can be trashed. I´m not sure if it´s double-layer or multi-layer. The holes seem very tight on the pins and there´s solder on both faces of the card, on all pins.
I do have some ideas, but not the right tools (I wish I had a Dremel)... So I´d like to hear your ideas on this. All help is highly appreciated!
Thanks,
Alexandre
Old 18th February 2006, 02:27 PM   #2
testlab is offline testlab  United States
testlab's Avatar
The best way to remove this IC is by using a very expensive vacuum desoldering iron. Second choice is to get a cheap desoldering iron like the Weller DS-40. You can also use the non-heated pump vacuum type in combination with some type of solder wick. In all cases, you should also use liquid RMA flux. Flux is your friend.
It's not whether you win or lose, it's how you lay the blame.
Old 18th February 2006, 03:21 PM   #3
sam9 is offline sam9  United States
sam9's Avatar
It is much easier to save the board than the IC. It's hard to get a DIP package off a through hole board even with a good solder sucker.
If itbwere my problem I wopuls suck out as much solder as possible and if it still doesn't come out gently, I would get out the Demel tool and cut the board *carefully*right up to the pins to expose them the complete the desoldering
Old 18th February 2006, 03:24 PM   #4
sagarverma's Avatar
use solder braid in combination with a good soldering iron.the braid can easily suck out the solder,the ic will come out easily.
Never Underestimate The Bandwidth of A Station Wagon Full Of Magnetic Tapes Hurtling Down The Highway...................Andrew S Tanenbaum
Old 18th February 2006, 04:26 PM   #5
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Originally posted by sagarverma
....,the ic will come out easily.
Depends; some do, some don't.
If it doesn't come out by removing solder,use the opposite method: Melt lots of solder and spread it down each row in turn. The IC will fall out by gravity. Do the job as quickly as possible with the highest wattage iron to hand - 2 if you have them.
Old 18th February 2006, 04:42 PM   #6
Electrons are yellow and more is better!
peranders's Avatar
If you don't care about the pcb, use fire! Cigarette lighter or gasol burner.
/Per-Anders (my first name) or P-A as my friends call me
Old 18th February 2006, 04:46 PM   #7
bob_v5 is offline bob_v5  England
as you dont have a dremel you could score along where you want to cut then snap the board. You have to make a deep score and bend it slowly tho. The blue lines on the pic are where you should cut. Make sure you cut right across the board.
Old 18th February 2006, 04:49 PM   #8
VT67 is offline VT67  Belgium
VT67's Avatar
Or you can use an electric powered paint stripper, you know that thing that looks like a hair dryer. Heat the board from the bottom side where the IC is located.
Old 18th February 2006, 04:51 PM   #9
dhaen's Avatar
Default Eek!
Be sure to use one of the thermostatically controlled ones
Old 19th February 2006, 12:35 AM   #10
Thanks for all the replies. I´ve been practicing on some other ICs with a desoldering pump, but I don´t think this will do.
I actually liked the fire idea (by peranders), but I´ll leave that as a last resort!
Someone suggested using two irons at once, thats nice! I think I´ll try bending copper wire to an "L" shape and use this tip on the iron, to touch the entire row of pins.
I´ll let you all know how it goes!
Best regars,
Alexandre
Ho to remove Multi Pin IC"s without special tools?? Minion Parts 14 11th May 2008 06:45 AM
Constrained layer damping / thin metal / fibreglass layer RobWells Multi-Way 3 6th August 2007 05:50 AM
Multi purpose multi channel gainclone PCB: Team project - group buy rick57 Chip Amps 14 29th March 2003 05:54 PM
Page generated in 0.10272 seconds (80.17% PHP - 19.83% MySQL) with 11 queries
