Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
A twisted tale about a logarithmic relay attenuator
Old 9th March 2006, 01:48 PM   #101
Nordic is offline Nordic  South Africa
Nordic's Avatar
Lol Brian, we appreciate what you guys do....
Another question... Could boards be so adjusted that one can use balanced or unbalanced inputs, say, flipping a switch.
Old 9th March 2006, 01:51 PM   #102
BrianDonegan is offline BrianDonegan  United States
BrianDonegan's Avatar
Yes, it works that way automatically. If you set it up for balanced opperation (two relay boards), single ended inputs will work fine.
Old 9th March 2006, 02:00 PM   #103
promitheus is offline promitheus  Europe
promitheus's Avatar
Can you guys make a PCB to adapt a Lorlin rotary switch that can switch the input with one contact and switch on LEDS with the other contact.
Something like the Aleph P would be cool where the LEDS are in a circle or line beside or above the selector knob.
Old 9th March 2006, 02:28 PM   #104
For the attenuator or the source selector?
For the attenuator, we use a pot, not a rotary switch, so that would not work.
For the source selector (Darwin) you could do it with a single deck rotary switch. Just run GND to the switch's common, then from each position tap back to the darwin input header. Then run +5V to the LEDs+ (common) and a resistor from the switch taps to the LED-. There is no audio signal going through the switch, so no worries there, and the switch can be a cheaper unit.
Old 14th March 2006, 02:06 PM   #105
So, about the kit resistors...
Russ and I have talked it over quite a bit. I am currently planning on including Phoenix MRS .6W resistrs in the kits. Here's the
datasheet.
We also discussed Dales (RN60), but they are fairly large for this board. Comments?
Old 14th March 2006, 02:11 PM   #106
joster is offline joster  United States
'fairly large' as in uncomfortable, or won't fit?
Old 14th March 2006, 02:26 PM   #107
Russ White is offline Russ White  United States
Russ White's Avatar
They will fit, but not as well. RN55s would fit better.
The Pheonix I think are the best choice.
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 22nd March 2006, 06:53 PM   #108
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
For this to work you have to use 2 boards right ? because it is balanced input. You'll need one board per input.?
Old 22nd March 2006, 06:57 PM   #109
For balanced operation, yes, two relay boards. For Single Ended, one relay board.
Old 22nd March 2006, 06:59 PM   #110
Banned
One more question. This will allow me to use regular rca in and use balanced out right. ? I'm new to this balanced stuff.
A twisted tale about a logarithmic relay attenuatorHide this!Advertise here!
F.S.: Joshua Tree - A Twisted Log Attenuator Cobra2 Swap Meet 2 20th September 2010 11:23 PM
Yet another relay attenuator jwb Solid State 34 21st July 2010 07:17 AM
Constant impedance relay-resistor logarithmic attenuator x-pro Pass Labs 75 27th June 2005 11:12 AM
relay based attenuator squadra Solid State 21 1st December 2004 10:10 PM
Ladder relay attenuator or so? Eccu Solid State 0 6th October 2003 11:00 AM
