Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 20th July 2009, 07:49 PM   #641
Default Impedans
I am interested in the volume control but I think the impedans is all too low for my purpose.
Old 2nd September 2009, 12:36 AM   #642
Beefy is offline Beefy  Australia
Originally Posted by PB2 View Post
I know that this post is old but I'm looking at LOG attenuators and just wanted to offer a comment.
While the individual spec for the I/O pins above is correct, the absolute total for the PIC16F685 PIC
is 200 mA for all the ports. Your calculation:
20mA * 14 (all on) = 280mA........
So just to confirm what is being said here (and in Brian's original post three years ago), a balanced Joshua Tree would draw over 0.5A of current?
Old 3rd September 2009, 10:19 PM   #643
for the relays (there are 8 per JT and for balanced mode you will need 2JT's), the calculation would be:
5v / 237ohms = 21mA * 8 relays * 2 JT's = 0.33A
This is ofcourse a worse-case scenario, so 0.5A is in the right ball-park.
Originally Posted by sjalloq
I was planning on using my own encoder along with MCU board. If I want to integrate it with your relay driver board what do I need to know?
as mentioned, you need to drive the relays to ground using a ULN2803. This sinks all the current so your pic won't melt
Coupled to a 74HC595, the code to control a JT (using SPI) is surprisingly simple.
Mike
Old 4th September 2009, 12:06 AM   #644
BrianDonegan's Avatar
We use I2C rather than SPI, but, same difference. It's pretty simple. The trick is the hysteresis and averaging to prevent constant value changing.
Old 4th September 2009, 08:27 AM   #645
Brian
I would assume though that you use the hysteresis averaging because you are using an analogue pot, if sjalloq wants to use an encoder instead, then I don't believe this is an issue.
Mike
Old 4th September 2009, 01:23 PM   #646
Originally Posted by MikeBarton View Post
Brian
Mike
Correct.
Old 2nd October 2009, 03:45 PM   #647
Keyoke is offline Keyoke  United States
Hate to revive an already lengthy post - but is there a 'fixed' schematic available? I didn't see one on the twisted pear site, and the ZIP (on page 4 or 5 i believe of this thread) is no longer a valid link...
Old 14th October 2009, 08:09 AM   #648
thor2 is offline thor2  Denmark
Originally Posted by Hurtig View Post
Cut the crap!! Software isn't my business! My main focus areas are:
- Digital to analog conversion (Which was my special during my education)
- Analog electronics (Also my special)
I know your special is more like this: http://web5687.web04.talkactive.net/...bforforamp.jpg
I am more into making electronics like this: http://img522.imageshack.us/img522/7730/pict2819vm3.jpg
For those who don't know Erlend Sæterdal, please feel free to ask me. His intentions isn't what they look like
But let's have some of the users of Diyaudio decide... Guess you have to make a bunch of fake profiles, to wote for you (Like all the other forums).
There is no reason to laugh about this Hurtig.
Printed on the front plate is a completely full volume with the remote control: volume, phase switch, mute, four memories for volume setting , input select, max output setting, sleep timer, etc.
perhaps it is not so nice, but it is far above your level,
A closer look here:
http://tkhifi.homepage.dk/javapro/Ir_system1_3.jpg
It is built around an AVR controler.
and the sound of this preamp is fabulous
Old 7th June 2010, 12:04 PM   #649
novec is offline novec  Norway
novec's Avatar
Send a message via MSN to novec
Is the firmware posted anywhere?
Old 7th June 2010, 01:10 PM   #650
F.S.: Joshua Tree - A Twisted Log Attenuator Cobra2 Swap Meet 2 21st September 2010 12:23 AM
Yet another relay attenuator jwb Solid State 34 21st July 2010 08:17 AM
Constant impedance relay-resistor logarithmic attenuator x-pro Pass Labs 75 27th June 2005 12:12 PM
relay based attenuator squadra Solid State 21 1st December 2004 11:10 PM
Ladder relay attenuator or so? Eccu Solid State 0 6th October 2003 12:00 PM
Page generated in 0.14192 seconds (80.97% PHP - 19.03% MySQL) with 11 queries
