| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#501 |
Great news! Is said controller of the uber variety? ;D
#502 | |
Yes. But we dropped the "Uber" name in favor of "AC1" which stands for audio controller number 1. ![]() The reason is we want to reserve the term uber for later possibly. ![]() It will be used along with another module we have called "Femto". Which is basically a micro controller on a little board with a USB port. The Femto can be reprogrammed by users with just about any PC. This allows us to easily push out firmware. And it allows us to use the same basic controller for many applications. AC1 is basically an application mother board which the Femto module plugs into. Cheers! Russ
Less pulp more juice Twisted Pear Audio. |
#503 |
Great idea with the Femto. I'll be looking forward to details on the AC1 and Femto (even footprint).
#504 | |
Twisted Pear Audio |
#505 |
Here is what it looks like.
#506 |
And here is the Femto.
#507 |
And here is the driver.
Also Opus sized.The Driver board can be given a 3 bit address. This allows for independent control. Also note this driver will work for the Darwin. ![]() Also note it has it own PS to help spread the load for driving lots of relays. Cheers! Russ
#508 |
I'm still having some slight trouble with my Joshua Tree. At the lowest attenuation setting, I'm still hearing music passing through. And judging by the addition of the mute relay in MKII, does that mean the old Joshua Tree boards only attenuate but don't fully mute?
Is there a way to wire in full mute? |
#509 | |
The older JT attenuates from 0 to -63.5db in .5dB steps, so, no full mute. Without adding another relay or switch somewhere, you can't do full mute with it.
#510 | |
the JT boards don't *look* to be opus footprint, but looks are deceiving I suppose in this case. |
| F.S.: Joshua Tree - A Twisted Log Attenuator | Cobra2 | Swap Meet | 2 | 21st September 2010 12:23 AM |
| Yet another relay attenuator | jwb | Solid State | 34 | 21st July 2010 08:17 AM |
| Constant impedance relay-resistor logarithmic attenuator | x-pro | Pass Labs | 75 | 27th June 2005 12:12 PM |
| relay based attenuator | squadra | Solid State | 21 | 1st December 2004 11:10 PM |
| Ladder relay attenuator or so? | Eccu | Solid State | 0 | 6th October 2003 12:00 PM |
| Page generated in 0.10798 seconds (80.92% PHP - 19.08% MySQL) with 11 queries |
