Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 1st March 2008, 06:04 PM   #481
There is a buffer then the pot and then a gain stage.
As in the Naim 32.5 preamp.
Old 21st March 2008, 09:28 PM   #482
I have built the JT and put it in my Naim style preamp. It sounds great. Many thanks Russ and Brian.
It's early days but it appears that quite a few aspects of the music are better: dynamics, bass for a start.
Old 9th April 2008, 07:14 AM   #483
Default JT kit
Hi Russ,
will the Jshua Tree come back in stock in the next time ?
Old 9th April 2008, 12:18 PM   #484
BrianDonegan's Avatar
The Joshua Tree is being redesigned. We will post details when things firm up a bit.
Twisted Pear Audio
Old 9th April 2008, 01:26 PM   #485
Russ White's Avatar
Send a message via Yahoo to Russ White
Default Re: JT kit
Originally posted by DFroehlich
Hi Russ,
It will not be long.
Joshua Tree has proven to be a solid design. So I will not change it much. Just adding some refinements and design changes necessitated by my new pluggable controller design.
I am actually working on it today, and should be ready to order the PCBs in the next week or so depending on how much time I can dedicate to it.
What I have in mind should allow for both the simple control mechanism of the current JT controller (just a pot) as well as more advanced configurations such as rotary encoder and/or IR control as well as display.
Also in the work is a simple I2C relay driver board that will allow you do you existing JT boards and even Darwin. So you will be able to create a full featured preamp with this controller scheme.
The nifty part is that the controller is designed to detach from the main application board (call it a motherboard if you will) and it will have a USB connector on it. So I can disconnect the controller from the application and simply plug it into the PC and reprogram it. This makes it possible to use the same little controller for lots of different projects.
It is not a trivial project. And it may be a bit complex for some users. I will do my best to document it. I will also have some example firmware for common applications.
Cheers!
Russ
Less pulp more juice Twisted Pear Audio.
Old 18th April 2008, 03:04 PM   #486
robmil is offline robmil  United Kingdom
Default what does it look like 'ELECTRICALLY'.
Rob here
Can someone please explain what this attenuator 'looks like' electrically. I have attached a PDF of what my standard Alps in my preamp looks like 'electrically'... you all know it.
I know there are others here that would also like to know.
Thanks a billion.
R
Old 18th April 2008, 03:07 PM   #487
Russ White's Avatar
It looks like a series of LPADs. Each with the same output impedance so that the final output impedance is nearly constant.
Cheers!
Russ
Old 19th April 2008, 04:21 PM   #488
What is an LPAD ?
cheers
Old 19th April 2008, 04:27 PM   #489
Russ White's Avatar
Simply put, it's a voltage divider.
Old 23rd May 2008, 08:02 PM   #490
MrMajestic's Avatar
Any updates on the new boards? I know you have a lot on your plates, but its not beginning of may anymore
F.S.: Joshua Tree - A Twisted Log Attenuator Cobra2 Swap Meet 2 20th September 2010 11:23 PM
Yet another relay attenuator jwb Solid State 34 21st July 2010 07:17 AM
Constant impedance relay-resistor logarithmic attenuator x-pro Pass Labs 75 27th June 2005 11:12 AM
relay based attenuator squadra Solid State 21 1st December 2004 10:10 PM
Ladder relay attenuator or so? Eccu Solid State 0 6th October 2003 11:00 AM
Page generated in 0.11885 seconds (78.96% PHP - 21.04% MySQL) with 11 queries
