| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#251 |
One is definitely in the works. But it will likely not be very soon coming, I am just now closing on my old home, and will be moving over the next couple weeks, then I will need to get my new workshop in working order so I can begin working on my hobbies again.
Less pulp more juice Twisted Pear Audio. |
#252 |
Twisted Pear Audio |
#253 |
Russ, you da man. Good luck with your transition into your new home. Do you envision encorporating a Darwin selector into your remote control too?
Brian, very cool. That's a lot more than one thought. Is that remote device available for purchase? Or at least the board/chips? Nice work. |
#254 |
Schematic of that one...
#255 |
It's just a prototype I made up... quick and dirty. It uses a Rentron Sony RC5 decoder chip and a quad half-bridge to drive the motor. The motorized pot I got surplus, super cheap, but works. It would be fine with a single 5V VReg, but I am thinking it should use a LM317 for the motor voltage, adjustable, to customize speed. I initially used 12V, but speed made it too sensitive.
#256 |
Is the motor too big a load to drive from the JT's 5V supply?
#257 |
Well, I put a rectifier on the board too so you could tap right off the trafo. I will test it with the JT trafo and balanced JT, but I shoudl be fine. When the motor is at full rotation and the clutch is slipping, it was only drawing 65mA at 12V. Need to check at 5V, but would guess it would be about 150-200mA or so. Shoudl be okay.
#258 | |
Yes definitely. Brian and I call it the "Uber Controller" because it will control JT,Darwin, and possibly even Kooka, and who knows what else.
#259 |
Brian I am glad you got that thing working!
Nice!
#260 |
My wife and son were away for the weekend...
| F.S.: Joshua Tree - A Twisted Log Attenuator | Cobra2 | Swap Meet | 2 | 20th September 2010 11:23 PM |
| Yet another relay attenuator | jwb | Solid State | 34 | 21st July 2010 07:17 AM |
| Constant impedance relay-resistor logarithmic attenuator | x-pro | Pass Labs | 75 | 27th June 2005 11:12 AM |
| relay based attenuator | squadra | Solid State | 21 | 1st December 2004 10:10 PM |
| Ladder relay attenuator or so? | Eccu | Solid State | 0 | 6th October 2003 11:00 AM |
| Page generated in 0.11003 seconds (78.55% PHP - 21.45% MySQL) with 11 queries |
