Replacement parts for old Realistic amp. - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 16th February 2006, 03:43 AM   #1
DcibeL is offline DcibeL  Canada
DcibeL's Avatar
Default Replacement parts for old Realistic amp.
Hi
I would like to give some life back to my dad's old Realistic SA-1000 reciever from the 70's. I am replacing the large electrolytic caps, the source selector switch, and the potentiometers. I am having trouble finding a rotary switch and pots that are the same as what is in this amp. The parts have a long threaded area so that it can reach past the thick metal front panel. See attached pic. Would anyone know where I could find a pot and/or rotary switch with long threads like this?
The volume pot is 200k, I didn't look at the others as they are not as important.
Thanks.
The power of Science compels you!
Old 18th February 2006, 02:45 PM   #2
testlab is offline testlab  United States
testlab's Avatar
A dual 250K pot should work fine. You should be able to get one through Mouser.
It's not whether you win or lose, it's how you lay the blame.
Old 18th February 2006, 03:06 PM   #3
DcibeL's Avatar
I have several dual pots laying around. The problem is the threads are too short on a standard pot so I cannot screw the nut onto the end of it. I think when I measured the length of the threaded area they were 3/8" long and that's "just" long enough.
Old 27th February 2010, 10:35 PM   #4
srinath is offline srinath  United States
I just got a sa1000 myself. I have a unrelated peoblem wiht it though.
Its got a 1/2 inch gap in the front of that wood panel on both sides. What was there and is there some way of putting somthign in there to cover that gap. Thanks.
Cool.
Srinath.
Old 28th February 2010, 04:13 PM   #5
Bigred is offline Bigred  Canada
There are plastic endcaps on the front panel which sounds like yours are missing. I had one brought to me a few years ago for repairs that was also missing just the one side. I ended up fabbing 2 matching pieces out of aluminum. I'll post pics of the end result when I find them.
Old 28th February 2010, 04:47 PM   #6
Yes cool, Thanks. Please put pics ... making stuff out of aluminum is my middle name.
Why not plastic though, Aluminum could conduct ... of course face plate is aluminum.
There seems to be a aluminum foil type thing on that part just seems to run top to bottom. What is that ? Shorting to that is not a problem ?
Thanks in advance.
Cool.
Srinath.
Old 28th February 2010, 05:39 PM   #7
Whoooo hooo works like a charm.
Quadravox I guess is all 4 channels ?
Oh, man I need more speaker wire.
Cool.
Srinath.
Old 28th February 2010, 06:28 PM   #8
Its not rocket science, use whatever you want.... plastic, wood, metal etc. Its simply cosmetic. I chose aluminum that I gave a brushed look to
Old 28th February 2010, 07:21 PM   #9
K that would work, and wood will match the veneer ... but I work aluminum better than wood. Thanks. See if you can post a pic. My imagination runs amuck ...
Cool.
Srinath.
BOZ replacement parts Elkaid Pass Labs 33 31st October 2005 03:40 PM
Replacement Parts AR1 Analog Line Level 2 11th July 2005 01:52 PM
replacement parts robbie b Parts 1 7th February 2005 03:15 AM
Looking for replacement parts jschen Parts 2 1st June 2004 02:59 PM
Copyright 1999-2017 diyAudio
