CPU Adhesive tape vs Silipad - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 6th November 2002, 08:51 PM   #1
Default CPU Adhesive tape vs Silipad
Folks:
After a frustrating hour in Fry's, I can not find extra Silipad insulators for my TO-3p mosfet's.
I did find some "CPU Thermal tape" which is for sticking a CPU to a heat sink. There's no grounding issues there, so I don't know if this will inslulate or not. It will be a mounting method (no bolts) as well as good thermal condutivity.
Do you think I can use the CPU tape for my amp?
== John ==
Old 6th November 2002, 09:16 PM   #2
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
What's TO-3p? Is it the same as TO-3? I've got a lot of these pads.
www.audiosector.com
Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it. - JC
Old 6th November 2002, 09:22 PM   #3
Banned
isnt TO3p = TO3 plastic synonym TO-247 ? i thought so.
Old 6th November 2002, 10:51 PM   #4
diyAudio Senior Member
fdegrove's Avatar
Default TO3
Silverloaded thermal paste works fine too.
And I do believe the P stands for Plastic Casing.
Frank
Old 7th November 2002, 01:48 AM   #5
Circlotron's Avatar
Default Thermal resistance vs voltage rating
Watch the thermal resistance on some of those silpad type materials. The ones with a high voltage rating (often used for SMPS's etc) have pretty ordinary thermal performance. Also, the thinner the pad/tape is, the flatter your surfaces have to be.
I think TO3-P is like TO-247 but with a bit of the metal tab exposed around the top edge, also the mounting hole is not insulated like in the '47.
GP.
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/multi...tml#post353269
Old 7th November 2002, 02:26 AM   #6
Right, like a TO-247; here's a picture:
Exicon 10N20
The non insulated is the big issue, it HAS to be isolated from the heat sink, or I'll be frying bacon instead of listning to music!
I don't see how thermal paste will help do that.
Where can I get some Silipad's? I couldn't find any at Mouser
== John ==
Old 7th November 2002, 05:19 AM   #7
Jean is offline Jean  United States
Jean's Avatar
Send a message via AIM to Jean
Digikey has to3p pads. BER178-ND
Old 7th November 2002, 05:22 AM   #8
sangram is offline sangram  India
'CPU thermal tape' does not insulate.
Old 7th November 2002, 06:09 AM   #9
Well, it's off to DigiKey then!
UPS is getting 1/2 of my project cost, one minimum charge at a time lol
Thanks folks, this forum is great.
== John ==
Old 7th November 2002, 06:17 AM   #10
Jean's Avatar
S/H from Digikey is cheap, order some extra components to make up for that minimum order fee.
Adhesive for ESL panel repair 405man Planars & Exotics 7 26th June 2014 08:24 PM
Adhesive For Hearing Aid Plastic kelticwizard Everything Else 10 31st August 2009 10:19 PM
removing old adhesive for a refoaming ichiban Multi-Way 3 7th August 2008 02:49 AM
Platter Laminating...Best Adhesive? valveitude Analogue Source 10 3rd November 2005 02:40 AM
Anybody knows where t oget cheapie self-adhesive copper tape?? li_gangyi Everything Else 8 13th December 2003 05:57 AM
Copyright 1999-2017 diyAudio
