| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I've only had experience with pic's, and those are limited to add, subtract, and to my knowledge basic routines for mult and div. Does anyone have any experience with higher level processors and know where to steer me? I'd like to be able to do math like trig, calc, DE's, etc. but hard coded into the hardware. I know I could potentially do something software based such as a mini via motherboard / linux or windows, but that seems overly extreme for routine, although complex, calculations.
BTW, I'm going to use this for redesigning my car ECU and integrating some other stuff. Not exactly audio related, but I got a lot of help with my orions on this forum so I figured someone might know something. In short, I need something somewhere in between a pic and and a desktop processor. |
#2 |
maybe you could use a "BASIC stamp" which is a little board that can run BASIC programs .
they have been around for a while, maybe there is something better now. im not sure what functions it supports but im sure google can help you with that |
#3 |
A BASIC STAMP is no use, they just run a slow BASIC interpreter inside a PIC.
I don't know of any micro-controllers with maths co-processors?, bear in mind it's only since the Pentium that Intel have been including them in their processors (the 486 only had some with them). I would suggest you need to think more about it?, sensible design will probably remove your requirement for it?.
Nigel Goodwin |
#4 |
If you're into car ECU design, have you looked at the Megasquirt and Megajolt projects on the web?
#5 |
There are newer PIC chips with a DSP core. While these do not support trigonometry and the like they can be implemented by software.
Regards Charles |
#6 |
I was just thinking. Does anyone know what chips are inside the TI calculators or HP?
#7 |
How about via nano ITX its 12x12 CM and about as powerful as a celeron 600 or so
#8 | |
#9 |
Modulo using some part with a heavy math coprocessor (hello Pentium!), doing trig involves math routines, ideally coded in assembly. The techniques are well-known (check Numerical Recipes for hints), and depending on the processor you might even be able to find prebuilt libraries.
Calculus is always done numerically in real-time contexts, but for most problems that's exactly what you want anyway. Long story short, for your application either you run a Pentium or you learn to really love assembler. Cheers & good luck, Francois. |
#10 |
Using real-time calculations in a car ECU puts very high demands on the processor, therefore (as far as I know), todays injection controllers simply look up pre-calculated values from (EEP)ROM.
| lesser of two evils, high level -> line level, digital volume control | mazurek | Solid State | 3 | 19th November 2006 12:25 AM |
| how to bring down line level signal to preamplifier level | deji | Solid State | 15 | 15th April 2004 04:13 PM |
| Is it true that the higher the BL of a subwoofer, the higher its lowest playable... | 454Casull | Subwoofers | 16 | 19th March 2004 04:28 PM |
| Flying higher and higher with the Doede Dac | Lucas_G | Digital Source | 139 | 27th February 2004 06:40 AM |
| Super-power amps - higher current better than higher voltage | Circlotron | Solid State | 34 | 28th June 2002 04:01 AM |
| Page generated in 0.08996 seconds (82.09% PHP - 17.91% MySQL) with 10 queries |
