Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 12th February 2006, 11:34 PM   #1
Onvinyl's Avatar
Default CF-Opamp
what current-feedback opamp suitable for high quality audio with very low input offset do you know of?
Is the AD811 with the 3mV top notch?
Rüdiger
Old 14th February 2006, 03:04 AM   #2
jcx is offline jcx  United States
ad811 was simply early not best or even very good by today's standards
search for asl dsl reciver or driver op amps from ad, linear, ti, ...
TPA6120 has good audio specs but few cfa's will have really low Vos by today's precision op amp standards (<1mV) - servo, manual trim or ac couple
Old 14th February 2006, 03:35 AM   #3
lineup is offline lineup  Sweden
lineup's Avatar
Analog.com
Two-Stage Current-Feedback Amplifier
by Will Drachler
The AD8011's excellent performance (table) and power economy are due to a unique two-gain-stage current-feedback architecture (Figure A1) and fabrication on Analog Devices's bonded-wafer extra-fast complementary bipolar (XFCB) process.
AD8011
lineup
Old 18th February 2006, 03:09 PM   #4
testlab is offline testlab  United States
testlab's Avatar
Current FB amplifiers are attractive because they are typically very fast and circuit bandwidth is relatively independent of gain. They are typically used for video amplifiers.
The down side for audio use is that, due to their speed, layout and output impedence matching can be critical. These things will oscillate at the drop of a hat. Also, the output impedences are not typically suitable for audio circuits.
It's not whether you win or lose, it's how you lay the blame.
Old 18th February 2006, 04:50 PM   #5
Electrons are yellow and more is better!
peranders's Avatar
Default Re: CF-Opamp
I have a couple current feedback amps in my bag. One of them with discrete design had 0.00046% distortion. I recommend that you read some about current feedback because they won't simply work in some applications and the reason is the feedback. The feedback mechanism is different compared to voltage feedback. Walt Jung has a chapter about this in his 1000 pages book "Opamp Applications" which can download from Analog Devices.
/Per-Anders (my first name) or P-A as my friends call me
Old 18th February 2006, 10:04 PM   #6
darkfenriz's Avatar
lineup
fig. A2a lower mirror is wrong
Old 3rd April 2006, 03:09 PM   #7
Onvinyl's Avatar
Yes, there are a couple of newer ones available. But, looking closer, i have not found any that has all the needed features the ad811 has:
- low voltage noise (mandatory)
- low input offset voltage (3mV max, however, I have 8 examples here, all measuring between 0.2 - 0.4mV) (mandatory)
- high slew rate (don't know how important that is at the end of the day, but the ad811 sounds good )
Due to bad PSSR of the ad811, one needs a good PSU, however.
any comments?
Rüdiger
How much NFB around an opamp? cuibono Chip Amps 4 19th August 2008 09:55 PM
Single supply opamp - unequal rail voltage and opamp selection Hans L Parts 8 19th February 2006 02:15 PM
Opamp Vcc computeruser Solid State 5 13th October 2005 03:27 AM
Regulate the psu of a power opamp with a similar power opamp? Franz G Chip Amps 34 19th October 2004 10:49 AM
opamp-amp petera Solid State 5 4th December 2001 11:39 AM
Page generated in 0.08957 seconds (76.62% PHP - 23.38% MySQL) with 10 queries
