Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 11th February 2006, 03:25 PM   #1
amperex is offline amperex  United States
Default New to ICs question........
Ever since I built an IC based preamp back in the 1970s that sounded horrid, I never played with ICs in audio. Simply used tubes for DIY all these years.
What is interesting compared to tubes is finding IC pin out data. Am I to assume all 8-pin dip OP Amp ICs have the same pinout? It is never mentioned here.
For example OPA604. Performing a Google search using words OPA604 with 'pin out', 'schematic'. 'specifications', 'data', 'wiring diagram', etc, I do not find a diagram showing what each pin is for.
I wish to upgrade TL071 to OPA604 without building an adapter. Yet, not sure if the OPA604 will be pin compatable (plug & play).
Old 11th February 2006, 03:37 PM   #2
Do a Google search for
"OPA604" "Datasheet"
You can't be sure that all 8-pin opamps are pin for pincompatible, but the first page of the datasheet should give you a pinout diagram.
Old 11th February 2006, 03:48 PM   #3
Netlist is offline Netlist  Belgium
Netlist's Avatar
In many cases 'opa604' (or any other device) 'pdf'
gives good results as well.
/Hugo
Old 14th February 2006, 01:13 AM   #4
Enzo is offline Enzo  United States
I am not aware of any dual op amps in an 8 leg DIP that vary from the "standard" pinout. The data sheet will surely have the pinout though.
Old 23rd February 2006, 04:14 AM   #5
fdeck is offline fdeck  United States
I have also never seen a single op amp that strayed from the standard pinout for pins 2,3,4,6,7. Pins 1,5,8 can have different purposes, including offset nulling, compensation, and shutdown.
That OPA part is made by Texas Instruments www.ti.com. In most cases it should be able to replace a TL071 without an adapter.
Why the 604? What's the application?
BTW this is my first post to DIY Audio. My background is that I am a physicist with a keen interest in electronics, audio, and music.
Old 23rd February 2006, 07:29 PM   #6
I read the OPA 604 was a good upgrade by another person. I received a pair & it sucked. Not a good recommendation.
I am now going to try the TLE2071CP.
Old 23rd February 2006, 08:32 PM   #7
What is the problem you're having with them?, if you're expecting 'valve/tube' type sound from them you're going to be serious dissapointed, opamps are far cleaner than those - so you get to listen to the sound, and not the valves!.
Nigel Goodwin
newbie with input tran. question and wiring question imo Solid State 0 18th January 2006 10:10 PM
Capacitor Question /question on cap TunaFish Tubes / Valves 14 12th January 2004 02:23 AM
PS question - tformer question actually breguetphile Chip Amps 2 30th May 2003 01:29 PM
old speaker question, bullet midrange question & link to speaker project wallijonn Multi-Way 10 5th November 2002 06:03 AM
Page generated in 0.08023 seconds (76.54% PHP - 23.46% MySQL) with 10 queries
