Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
need help in correcting errors urgently
Old 9th February 2006, 02:22 AM   #1
weifeng is offline weifeng  Singapore
Default need help in correcting errors urgently
hi,
i m working on a DS1307 RTC program. i am using MPLAB IDE/C18 compiler. while trying to build the program, there are errors in it. can anyone help mi with the errors? i nid to get it done soon... the line in red is a syntax error...thanx
#define DS1307_SDA PIN_B1
#define DS1307_SCL PIN_B0
void boot_up(void);
void rtc_programming(void);
void read_rtc(void);
// initial DS1307
void init_DS1307()
output_float(DS1307_SCL);
output_float(DS1307_SDA);
// write data one byte to
// DS1307
void rtc_set(unsigned char rtcreg)
short int status;
i2c_start();
i2c_write(0xd0);
i2c_write(address);
i2c_write(data);
i2c_stop();
i2c_start();
status=i2c_write(0xd0);
while(status==1)
i2c_start();
// read data one byte from DS1307
byte read_DS1307(byte address)
byte data;
i2c_start();
i2c_write(0xd0);
i2c_write(address);
i2c_start();
i2c_write(0xd1);
data=i2c_read(0);
i2c_stop();
return(data);
Old 9th February 2006, 09:31 AM   #2
Tom2 is offline Tom2  United States
I am guessing.
It has been a long time since I wrote a C program.
I looked up the MPLab C18 Compilier Users Guide.
The word "byte" is not an integer data type.
Use "unsigned char". (0-255)
Tom
Old 10th February 2006, 07:38 AM   #3
hi,
i've alreadi tried using unsigned char, but still the same syntax error cums out.
Old 10th February 2006, 10:35 AM   #4
In the previous function void rtc_set(unsigned char rtcreg)
you use the variable names "address" and "data". The variable names are not defined and values are not assigned to them. Are they then global variables?
If the variable name "address" is a global variable then using it
as a variable name in your problem function might give you problems.???
Also in the function void rtc_set(unsigned char rtcreg) ,
the variable rtcreg is not used???
Are the names "address or data" reserved words?
I'm out of ideas. Back to power jfets.
Tom
Old 13th February 2006, 01:10 AM   #5
hi,
thanx for ur help.
but i duno hw to define the address and data...
Old 13th February 2006, 01:54 AM   #6
Sparhawk is offline Sparhawk
Sparhawk's Avatar
As has been already mentioned, check that the word "address" isn't a reserved word. Also, I don't see a prototype for the read_DS1307 function.
I've never used the MPLab compiler, though.
need help in correcting errors urgentlyHide this!Advertise here!
Yamaha NS-1000 Tweeters Wanted Urgently hugomac Multi-Way 33 20th December 2013 07:19 PM
My first LM3886 project (please help urgently!!) Derfla Chip Amps 13 20th March 2008 03:08 PM
Help Needed on ADC Urgently!!! wernchern Analogue Source 0 28th June 2004 04:00 AM
Copyright ©1999-2017 diyAudio
