| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Did it Himself
If I build a discrete bridge rectifier using 4x 100V diodes, is the bridge rectifier as a whole rated to 200V?
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#2 |
Hi richie00boy,
I would think 100V. It is reverse biased on alternate cycles with one end being the rectified voltage close to peak, the opposite goes the other way. -Chris |
#3 |
Did it Himself
Yes, but the current has to pass through two diodes on the journey. I an interested in the theoretical answer but also from a practical viewpoint as I currently have a bridge made from 100V diodes running off a 45VAC winding and has been given some abuse without blowing.
#4 |
Electrons are yellow and more is better!
45 VAC and 100 V diodes is a bit weak. 200 V at least. You must also have incoming voltage transients in mind.
/Per-Anders (my first name) or P-A as my friends call me |
#5 |
Did it Himself
Yes but from a purely theoretical view, is a bridge made from 100V diodes rated to 200V?
As 45V * 1.414 = 63V which when doubled to take into account of reverse bias bridge gives 126V yet my bridge has not blown up.
#6 | |
Reverse voltage on each diode is Vpeak-Vdiode(on)=ca Vpeak like Chris already said. Regards, Milan |
#7 |
Did it Himself
Thank you, that is the kind of answer I was looking for.
#8 |
Did it Himself
So what about half wave voltage doublers? I used 60V diodes on a scheme similar to this
![]() Schematic copyright Rod Elliot, sound.au.com but they blew up with an 18V transformer. Yet 18*2*1.141=51V which should be within their capabilities.
#9 |
a bit off topic but why on earth are you feeding 51Vdc into a 7815/7915? They are almost certain to blow. With or without a load on the end. Or is your circuit only delivering 25Vdc to each? So back to topic Is a 4 by 100V diode bridge equivalent to 100V or 200V PIV?
regards Andrew T. |
#10 | |
In theory it would be 200V, as the two diodes are effectively in series in each side of the bridge. BUT!, there's no voltage sharing resistors across them, so they won't be accurately balanced - so it will be greater than 100V but less than 200V (the exact value depending on the exact spec of the individual diodes). Personally, I'd still rate it as a 100V bridge, if you want 200V, then use better diodes! - the price difference is pretty insignificant.
Nigel Goodwin |
| diode bridge - 10000uF cap - diode tube - small cap - HV+ | engels | Tubes / Valves | 5 | 29th January 2008 10:16 PM |
| hybrid power supply: diode bridge into diode tube | engels | Tubes / Valves | 8 | 24th September 2007 09:18 AM |
| Diode bridge as loop breaker question | Tyimo | Pass Labs | 42 | 9th March 2007 04:21 AM |
| Page generated in 0.10624 seconds (76.59% PHP - 23.41% MySQL) with 10 queries |
