Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 6th February 2006, 04:57 AM   #1
dsavitsk's Avatar
Question Small, Inexpensive High Quality Film and Foil Caps
I am looking for the impossible. I am trying to find, as the subject says, small (narrow anyway) inexpensive high quailty film and foil caps (0.1uF). The Wima FKP2's are just slightly too wide as are the Dayton/Solens.
These are to be used for decoupling on a TDA1541, so I need 14 (hence inexpensive) and small so they can get close to the pins. I am happy to put every other one under the PCB but that still leaves a maximum width of about 4mm. Any suggestions?
Old 6th February 2006, 10:26 AM   #2
analog_sa's Avatar
Have you considered Siemens stacked film? BG NX is another interesting option.
Old 6th February 2006, 10:06 PM   #3
dsavitsk's Avatar
Do you have a source for these? I am unable to find them anywhere.
Interesting. Do you have experience that these would work well?
Old 7th February 2006, 12:36 AM   #4
I think the Vishay / BC component low voltage stack film type may be slightly slimmer (but deeper) than the Wima FKP2 but am not 100% sure. I have them at home but not at work (now).
Old 7th February 2006, 12:48 AM   #5
wrenchone's Avatar
Panasonic makes some small low voltage stacked film capacitors, if you don't mind polyester. They are readily available from Digi-Key.
Old 7th February 2006, 01:25 AM   #6
Epcos/Seimens stacked polypropolene film caps might be appropriate from Digikey, these are very low inductance metalized (not foil)caps, appropriate for bypassing -
http://www.digikey.com/
and search on 'B3262'
apply a filter to specify value and/or voltage, or simply hit 'viewpage'
click on one of the Digikey part #s, then the catalog/technical info, and you can pull the pdf.
If you need voltages and/or values beyond what is available in stacked polypropolene, Epcos also makes stacked polyethelene caps. Simply search at Digikey for 'B3252'. Note - above certain voltages/values these are mixed stacked/wound or wound caps with higher inductance. You need to download the pdf to see which is which.
Small but high quality tweeters? Tenson Multi-Way 3 22nd January 2007 03:55 PM
Source for a high quality y-rated film cap? Colescuttle Parts 1 13th January 2007 07:50 PM
Wanted: 8.2uf poly or film & foil caps KevinLee Swap Meet 1 20th November 2005 08:02 PM
small, but high quality amp Sukandar Solid State 19 14th November 2003 10:19 PM
inexpensive film and foil caps mm Parts 3 27th April 2003 06:29 PM
Page generated in 0.08634 seconds (74.99% PHP - 25.01% MySQL) with 10 queries
