Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
need help with getting a digital multimeter
Old 8th February 2006, 09:52 AM   #11
R.I.P.
the spec for the frequency range of voltage reading ability should look just like that for amplifiers. eg. 20Hz to 500Hz +0.5db -3db or something much superior to suit your requirements.
If you arrange to make comparisons of almost identical voltages then the response errors of the DMM can be almost eliminated to quite high frequencies. I use mine upto 200kHz but it's spec is to only 500Hz.
Asumming my sine wave generator is putting out nearly constant voltage as I sweep through the frequency range, I find that a 1990mV signal at 100Hz appears to have fallen to about 160mV when reading a 100kHz signal, but comparison negates that big apparent error.
regards Andrew T.
Old 8th February 2006, 09:59 AM   #12
darkfenriz is offline darkfenriz  Poland
darkfenriz's Avatar
Default Re: need help with getting a digital multimeter
Originally posted by ad_breaker
.... so here's what I need: something that also measures low ohms, capacitance, and frequency and it MUST be able to do accurate AC voltage measurements over the 20hz-20khz range. RMS and a dB readout option would also be nice.
You forgot the most important: 'diode' buzzer (beep-beep).
Priceless tool when debugging circuits.
Old 8th February 2006, 11:46 AM   #13
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
The Fluke 89 IV is a very nice meter but I think what you're really after is an AC test set AND a DVM. As has been pointed out, DVMs have their limitations at AC and the true RMS feature is rarely of use in audio. You might like to have a look at the Neutrik Minilyser.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 19th February 2006, 02:00 AM   #14
mnemneth is offline mnemneth  Scotland
Default Frequency measuring multimeter
Hi guys,
in this day and age, there is no requirement to spend megabucks on test equipment.
The far East is falling over itself to provide cheap and accurate measuring kit.
This item would probably do the business for the original poster;
http://www.jaycarelectronics.co.uk/p...=&SUBCATID=546
A lot less than $200 and certainly seems to meet his requirements.
I've dealt with thios supplier and they are excellent.
HTH,
Sandy
Old 19th February 2006, 02:13 AM   #15
anatech is offline anatech  Canada
anatech's Avatar
Hi ad_breaker,
Everything Hugo, EC8010 and AndrewT said.
Fluke makes about the only accurate handheld DMM out there. It is the only one that will hold it's calibration. I know you are not going to send your meter in every (even) two years for calibration.
Buy the Fluke. <- period
I worked as a calibration technician, this is a fact. I have some Fluke handhelds.
Sandy,
Sadly, no that meter can not be trusted. Many techs spend good $$ on bench meters. Mine was around $1,500. They can go higher too. There is very good reason to spend money on good test equipment. Think of it as an investment, not unless you only have to check if the mains are present, the fuse is good and the battery has voltage. Then all you need is a couple of test lights and a continuity tester.
-Chris
need help with getting a digital multimeterHide this!Advertise here!
Digital Multimeter recommendation tempoct Parts 67 4th November 2007 09:40 PM
Digital Multimeter accuracy? tempoct Parts 6 4th February 2006 04:58 PM
which is good DIgital auto range multimeter. boxedin Parts 8 23rd December 2005 03:57 PM
Digital Multimeter Extech? kaushama Parts 1 26th October 2005 05:20 PM
Digital Multimeter speedstar Digital Source 2 20th July 2004 02:56 PM
