| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hello,
I would make a relay based attenuator, controlled with microcontroler. But I'm wondering wich relay to use, normal or dual coil (bi-stable in french). I think dual coil is better for noise and heat but is there a difference in life-time? Thanks |
#2 | |
Antoine http://dmsaudio.ca/ |
#3 |
Un relais "reed" durera beaucoup plus longtemps -- and is much faster as well.
#4 |
I didn't know reed relays... Seems interesting!
Are there some disadvantages compared to normal single coil relays? Ok, found some, magnetic fields around it can switch it. So it should be shielded also. As for advantages, I found a lot of them : Longer life, sealed contacts, etc. By searching a bit... Wet reeds are better I suppose?(Except for the fact that the difference is the mercury...) They are pretty silent I think also. By looking at some, I found that the relays in my synth are reed relays, and they don't make noise at all.
#5 | |
http://www.pickeringrelay.com/ C'set vraiment très rare de rencontrer des gens qui ignorent que la langue officielle dans ce forum c'est l'anglais, mais ça me donne l'occasion de pratiquer mon français médiocre! |
#6 | |
... Hey, we're all from different countries in this topic also!
#7 | |
Hopefully you did not take this too seriously , just joking because I had the opportunity to practise a little! |
| Looking for the best relay | carlmart | Solid State | 15 | 19th August 2005 12:06 AM |
| Connecting a relay | DragonMaster | Everything Else | 8 | 3rd March 2005 09:38 PM |
| Can I use a SIL relay ? | Ryssen | Solid State | 8 | 29th December 2003 10:45 PM |
| Help with relay | ppereira | Solid State | 14 | 21st June 2003 08:10 AM |
| Relay or not relay ? | Yonnat | Pass Labs | 10 | 10th April 2003 07:26 PM |
| Page generated in 0.08782 seconds (74.08% PHP - 25.92% MySQL) with 10 queries |
