| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I already have a 200R quad pot I would like to make use of in a preamp I am building since quad pots are not trivial to source. The op amp driving aginst the pot is an OPA1632. I don't see a problem, as the OPA should be able to drive this load and the amp should work fine with a lower-Z input. Is this acceptable? I do have room to increase the gain on the OPA, and I was considering doing that and maybe putting 400R in series with the pot to bring it up to a nominal 600R. Is that worth the effort?
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#2 |
Hi leadbelly,
I was waiting for someone to give you a reply. I don't believe this is a good idea for the simple reason that you are making life hard for the op amp. Just because they can handle, say, a 600 ohm load does not mean you should. Distortion almost always increases with decreasing load impedance. You are increasing the dynamic impedance seen by the amplifier. You would be further ahead to use your quad 200 ohm control for something else. -Chris |
#3 |
Thanks Chris. I think I'll concentrate on rigging up multiple pots to do the job. A lot of effort but you get a payback of better signal separation too.
#4 |
Hi leadbelly,
Four channel preamp? Just wondering. 4 gang pots are not cheap and easy, you lucked into it? -Chris |
#5 | |
I can make do with a dual gang but prefer not to compromise. I'm handy enough to cobble up something that should track well, at least I hope I am A couple of quad gang pots came my way in a mess of goodies that a gentleman moving out of the country gave me. All low grade electronics, lots of stuff from India, but occasionally I find something useful in there.
#6 |
Hi leadbelly,
I understand now. You may want to go with a DAC or relay switched resistor network (the balanced lightstar preamp does it that way). Good luck with your project! -Chris |
| preamp output stage resistor from output to V- ? ? | Bernhard | Solid State | 4 | 19th October 2007 02:55 PM |
| preamp with output trannies. | then_dude | Tubes / Valves | 6 | 13th October 2006 05:06 PM |
| Preamp output delay | derekyu | Tubes / Valves | 4 | 28th June 2006 05:49 PM |
| CD Player Output Vs. Preamp Output For A Sub. | kspv | Multi-Way | 3 | 16th April 2004 10:45 AM |
| What's the advantage of having a high (+-200R) output impedance? | Bricolo | Digital Source | 9 | 8th February 2004 12:56 AM |
| Page generated in 0.06739 seconds (84.02% PHP - 15.98% MySQL) with 10 queries |
