Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 29th January 2006, 02:27 PM   #1
kmj is offline kmj  Sweden
kmj's Avatar
Default What kind of capacitor is this?
Hi, could someone tell me somthing about these sprague capacitors?
sprague 1uF 600V 118p10506s4
What I'm looking for is usage, quality, are they easy to get ahold of, estimated price and so on.
And what is Hermetpoly?
I'm asking because a friend of mine gave some of these to me, i'm not looking to sell them but it would be fun to know a value and usage for them.
best regards
Old 30th January 2006, 03:33 AM   #2
kmj's Avatar
I know that they where used in a Swedish fighterjet, in the guidingsystem I think.
Old 31st January 2006, 03:43 PM   #3
Location: Auburn, WA (somewhere between Seattle and Tacoma)
Send a message via ICQ to Damon Hill
They're 1 microfarad at 600 volts DC, probably plastic
film. "Poly" could mean anything; mylar, polypropylene,
polystyrene, in increasing order of quality. There are other
types of plastic film in roughly the same range of quality.
Since they're apparently military specification, they should
be very good build quality, depending on the type of
dielectric used. If you have a voltmeter and a power supply,
charge one up (no more than 50 volts DC for safety reasons)
and then short the leads together after the capacitor has
been charged for a few minutes. After discharging the capacitor,
separate the leads and measure the remaining voltage. The
lower the voltage the better the quality of the dielectric.
Polypropylene should read below .1 volt after discharge, and
stay fairly low. Mylar will read higher and may rise to several
volts, which is less desirable (the plastic film has a 'memory').
If the body or leads are magnetic, this is less desirable, but
hardly fatal.
Most likely application might be in speaker crossovers, coupling/
bypass capacitors in tube power supplies. Don't use them in
AC power line circuits unless they are specificially designed for
that application! They probably won't fail, but it's >how< they
fail that's important.
Old 31st January 2006, 04:19 PM   #4
kmj's Avatar
thanks
IŽll check at work if the electricians have something to check them with.
Old 31st January 2006, 04:29 PM   #5
hermet = hermetically sealed, poly = polyester.
/sreten.
Old 31st January 2006, 05:04 PM   #6
kmj's Avatar
yeah, but isn't all modern caps sealed that way?
What is kind of BHC capacitor??? thanhgamo Parts 1 24th May 2009 02:50 PM
Different kind of sub rjon17469 Subwoofers 7 16th November 2004 08:42 PM
what kind of filter capacitor in my Magnepan Tuur Multi-Way 1 1st October 2004 04:20 PM
Other Kind of DIY Algar_emi Everything Else 11 28th April 2003 12:48 PM
Page generated in 0.07783 seconds (76.27% PHP - 23.73% MySQL) with 10 queries
