| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Can someone tell me the function of D7 in the Quad 606 schematic in the attached link http://quad405.com/606schematic.pdf
Thanks Stuart |
#2 |
Quick guess is that it is there for biasing purposes.
It's not whether you win or lose, it's how you lay the blame. |
#3 |
quad is a challenge; weird circuit, poor signal flow in schematic
looks like d7 protects t9,10,11 from too much reverse base voltage - normally I would say it should only be a fault protection issue but the current dumping Qs do switch hard, t8? be junction should "catch" the drive signal with d6?(below d5) it also limits t8? drive and can limit output current in the low side output with r18?, 22 |
| Need help understanding TL431 | Archwn | Power Supplies | 33 | 21st May 2008 08:57 AM |
| Amp understanding / help | bear-hifi | Pass Labs | 1 | 7th February 2006 05:56 PM |
| Amp understanding / help | bear-hifi | Solid State | 2 | 7th February 2006 03:26 PM |
| Need help understanding something about UL stages | percy | Tubes / Valves | 2 | 6th January 2005 01:22 PM |
| Understanding the Aleph...? | Cobra2 | Pass Labs | 17 | 2nd June 2004 05:58 PM |
| Page generated in 0.07309 seconds (67.40% PHP - 32.60% MySQL) with 10 queries |
