| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
If Kiwame is rated the best sounding resistors by some people, does that mean only as emitter resistors, or amp-wide? I noticed that they only go as low as 2.2 Ohm at the suppliers sites that I saw them available. I sthat a good value for an emitter resistor?
Is it not better to burn out, than to fade away? |
#2 |
Emitter resistors are usually <1 ohm for outputs.
It's not whether you win or lose, it's how you lay the blame. |
#3 |
Hi hawkfeather,
Testlab is right about the values. Some Stassis amps use 1 ohm, and that's high for the average amp.. The most common values range 0.22, 0.33 and 0.47 ohms. The odd amplifier may use 0.1 ohm or nothing (gasp ). Using a low inductance part is very important. Too low a value and you may have trouble with current sharing or bias instability (read boom).-Chris |
#4 |
Excessively coloured IME
| Sugar vs MOX vs Kiwame | Malefoda | Multi-Way | 0 | 13th February 2008 07:33 AM |
| Kiwame resistors | pmillett | Tubes / Valves | 7 | 3rd February 2008 01:08 PM |
| feedback on kiwame please | jarthel | Parts | 1 | 25th May 2006 03:02 PM |
| Kiwame question... | hawkfeather | Solid State | 0 | 27th January 2006 12:51 AM |
| Riken Ohm Vs Kiwame | FREQUENCY | Tubes / Valves | 3 | 2nd April 2005 04:32 PM |
| Page generated in 0.07435 seconds (71.46% PHP - 28.54% MySQL) with 10 queries |
