Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Help me identifiy this connector
Old 21st January 2006, 06:38 AM   #1
MrTransistorm is offline MrTransistorm  United States
MrTransistorm's Avatar
Default Help me identifiy this connector
This connector is on a microphone preamp module. It plugs in to a channel strip on my Sony MXP-2000 console. I'd like to make my own mic pres for it, but I need to locate a source for the connectors.
The connector is 15 pin with 2.54mm pitch. It's probably a Japanese type. I was unable to find it on the Hirose, Honda or Tyco websites.
Dave//
Old 21st January 2006, 06:40 AM   #2
Here is the mating connector on the channel strip.
Dave//
Old 23rd January 2006, 09:42 PM   #3
TwoSpoons is offline TwoSpoons  New Zealand
TwoSpoons's Avatar
Are there any markings anywhere? Little symbols? Anything?
Have you tried: Harwin, AMP, Molex, JST, Neltron, Berg?
Old 23rd January 2006, 10:05 PM   #4
poobah is offline poobah  United States
poobah's Avatar
What is the the center to center measurement on the pins???
Old 24th January 2006, 03:06 AM   #5
The pins are 2.54mm (0.1 in.) on center spacing.
Now that I look more closely I see that there are markings on the back. There is the HRS marking, so it is definitely Hirose. The only other markings are pin numbers.
I looked through every possible connector type on the Hirose website, but to no avail. I'm guessing that this type has been discontinued (the Sony mixer is probably about 20 years old).
If I can't locate this connector, I think I might be able to use standard right angle header pins.
Dave//
Old 24th January 2006, 03:12 AM   #6
poobah's Avatar
If it is 2.54 mm then it is likely a knock off of an American brand... I've seen those before... maybe BERG?
Help me identifiy this connectorHide this!Advertise here!
Name this Connector thermionic Parts 7 16th July 2009 04:31 PM
Can I use 4-pin Molex connector as speaker connector? MikeHunt79 Everything Else 5 3rd June 2009 08:21 PM
F-connector vs. BNC pooge Digital Source 6 2nd August 2006 09:53 PM
AC connector alizawi Chip Amps 10 4th April 2006 03:43 AM
ATX connector MaXiZ Everything Else 15 3rd January 2006 09:02 AM
