Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Oscilloscope use.
Oscilloscope use.
Old 21st January 2006, 04:51 AM   #1
argonrepublic is offline argonrepublic  Canada
Default Oscilloscope use.
I am checking a clock OSC (hex inverter) for output with an oscilloscope. Please help. What settings on OSC? I have been reading tutorials but I need to check this IC now. Pin 8 output AC or DC? What range?
Old 21st January 2006, 08:00 AM   #2
Default Osc
When I first checked pin 8 with DVOM, I had supply voltage and .1 kHz. I wasn't sure whether meter was good enough for test. I tried with Osc (no experience). Prior to testing I used function generator to set my range and voltage on the Oscilloscope. Upon testing pin 8. My horizontal line raised in response to power up synth. I could not get a waveform. Does DC not have a waveform? Did my meter show my suspected shorted IC?
Oscilloscope use.Hide this!Advertise here!
Need help with oscilloscope error0 Equipment & Tools 2 6th April 2008 02:22 AM
Oscilloscope XTAL Parts 0 18th March 2005 06:05 AM
PC or USB Oscilloscope owel Parts 9 31st March 2004 09:55 PM
How to use an oscilloscope SimontY Equipment & Tools 15 16th September 2003 11:46 AM
oscilloscope Kilowatt Digital Source 12 22nd January 2002 01:30 AM
