Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Digital Multimeter recommendation
Old 7th October 2007, 05:32 PM   #61
jackinnj is online now jackinnj  United States
jackinnj's Avatar
Originally posted by Conrad Hoffman
Since I collect GR bridges from the 1940s on, I have to choose the rest of my equipment very carefully, so as not to collapse the test bench!
Do you have the GR Magazines from the 1940s and 1950s -- time was when GR, General Electric and RCA mailed monthly magagzines --
I use a GR Digibridge.
Old 7th October 2007, 05:51 PM   #62
Conrad Hoffman is offline Conrad Hoffman  United States
Yes, I have quite a few of the GR "Experimenter" mags, though I'd have to look to see what years. IMO, the publications of GR, plus their manuals, plus the manuals of HP and Tek, can be quite an education in themselves. I also have a basic Digibridge(tm) and use it for all my routine constructions. The fussy stuff goes on the 6 digit 1615, or a 716C if wider frequencies are needed. BTW, Henry Hall designed the Digibridge, plus some of the earlier bridges, and now runs the GR historical site through Terradyne (sp?). A heck of an engineer, and can answer just about any question relating to GR or impedance matters in general.
Old 29th October 2007, 03:06 AM   #63
MadMutt is offline MadMutt  Australia
Thread revival FTW
I'm trying to decide between a 77 mkIV or a 177.
I can't see any real difference between them.
Or am I missing something ????
Same case/display/functions.
Basic acurracy between them is so close it's not funny.
http://au.fluke.com/auen/products/Fl...a&category=HMA(FlukeProducts)
http://au.fluke.com/auen/products/Fl...ategory=HMASUB(FlukeProducts)
Price is slightly higher on the 177.
Why ???
Oh, and if anyone knows of a cheap supplier (in Aus) please tell........
I've got a price of $350 (77) and $370 (177).
Old 4th November 2007, 08:00 AM   #64
Never mind.
Got a 179 for $340 delivered.
So far works well.
Old 4th November 2007, 06:08 PM   #65
anatech is online now anatech  Canada
anatech's Avatar
Hi Madmutt,
I'm going to bet that it didn't take you long to make up your mind, did it?
Good going, now you should be a happy guy!
-Chris
"Just because you can, doesn't mean you should" my Wife
Old 4th November 2007, 08:59 PM   #66
Was more a case of cheap'n'crappy died and I needed a replacement reasonably soon.
Then while hunting for a price on the two (77 - 177) I found a new in box 179 for less than the others.
I still can't really see a major difference between the 77 - 177.
The display is really clear, even at odd angles.
When it's flat on a bench, of to the side, while your sticking conductive bits of metal into the small space of live equipment, that's a big plus.
Fast, reliable, and accurate.
Be happier if it had been cheaper still
But hey, I think they are spossed to be about Au$500 rrp, And that I recon is an utter rippoff.
They are good meters but geez I recon $300ish sounds more realistic.
Old 4th November 2007, 09:27 PM   #67
jnb is offline jnb  Australia
I'm looking for a meter that will do L, C and hFE, >800V, RMS, maunal ranging and fast response, if anyone might make a suggestion?
Old 4th November 2007, 09:40 PM   #68
With those needs you'll either be spending a lot for a decent meter (1,000) or look at getting several seperate ones.
the fluke 177 will cover caps up to 10,000uF, but doesn't do inductance or transistors.
And trust me on this, cheap meters with those functions end up in the bin fast (mine old one did)
Possibly the closest I can think of is the fluke 189 (~$900, but it's now obsolete so you might pick one up cheaper) or its replacement the 2xx ???
Have a look at the fluke aus site, then hit ebay, thats where I found mine.
For an inductance meter, elektor have a project called the 'Coil Clinic', I'm thinking about building one myself, will be around $100 finished.
Digital Multimeter recommendationHide this!Advertise here!
need help with getting a digital multimeter ad_breaker Parts 14 19th February 2006 02:13 AM
Digital Multimeter accuracy? tempoct Parts 6 4th February 2006 04:58 PM
which is good DIgital auto range multimeter. boxedin Parts 8 23rd December 2005 03:57 PM
Digital Multimeter Extech? kaushama Parts 1 26th October 2005 05:20 PM
Digital Multimeter speedstar Digital Source 2 20th July 2004 02:56 PM
