Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 18th January 2006, 07:58 PM   #1
dw887 is offline dw887  United Kingdom
Default Resistor for Audiolab 8000a
Hi
I have a problem with my Audiolab 8000a, which is the very early model with the 180 degree DIN sockets. The problem I have is with a resistor that I can't seem to source.
On the pcb it is situated just in front if the output transistors Q39 and Q41. It is a white 3 pin resistor and the marking on it are RGC33 - 0.22ohmKX2 - 32. Could somone with a bit of knowledge tell me what the wattage rating is for this component and also where I could get a hold of one. Other than that are there any suitable equivalents. I have a picture of the component at:Picture of resistor
David
Old 18th January 2006, 08:07 PM   #2
Steven is offline Steven  Netherlands
Steven's Avatar
2 times 5 Watt should be enough. Probably difficult to source such a double resistor, but you can as well use two separate ones.
Steven
The Analog Art shows no sign of yielding to the Dodo's fate. The emergence and maturation of monolithic processing finesse has perhaps lagged a bit behind the growth of the Binary Business. But whereas digital precision is forever bounded by bits, there is no limit excepting Universal Hiss to the ultimate accuracy and functional variety of simple analog circuits. - Barry Gilbert, 1973
Old 18th January 2006, 08:57 PM   #3
Hi Steven
Thanks for your response. Also could you verify that the output transistors fitted are the correct ones or at least a decent equivalent, they are 2 x BD911 and 2 x BD912.
Cheers
Dave
Old 19th January 2006, 03:00 AM   #4
testlab is offline testlab  United States
testlab's Avatar
What you have ther is what we call yer Noble dual emitter resistor. They seem to be difficult to come by lately. They can probably be found at a distributor that deals replacement parts for consumer electronics. You might try Futurelec. Or, discrete resistor with a 5W ratting should be fine.
It's not whether you win or lose, it's how you lay the blame.
Old 19th January 2006, 05:41 PM   #5
testlab's Avatar
Found what you need here :
http://www.mcminone.com/category.asp...3829947&Page=1
Old 19th January 2006, 05:52 PM   #6
Hi testlab
Thats great, thanks for taking the time.
Dave
Old 19th January 2006, 05:56 PM   #7
anatech is offline anatech  Canada
anatech's Avatar
Hi dw887,
Your original is a dual 3W, non-inductive. 5W is fine. The part testlab linked to is correct.
Don't use 5W "bathtub" style resistors. They are inductive and may cause you grief (oscillation). They also sometimes don't fit in the small space the original part takes up.
The 8000a schematic I have indicates 2SC4382 and 2SA1668 as drivers (same case style as your BD parts), 2SC2922 and 2SA1216 as outputs. Your version may be different, but I don't think it's that far different.
-Chris
Old 19th January 2006, 06:08 PM   #8
Hi Chris
Thanks you for the information. Have you had much experience in repairing the outputs on these amps? So far I have found:
Q38 - Short
Q39 - Short
Q40 - Short
Q41 - Short
Q31 - High Resistance
Q33 - High Resistance
Q45 - Short
Q49 - Short
Q47 - High Resistance
Q51 - High Resistance
Q35 - Short
And a 3 high resistance resistors.
If you have a pdf copy of the circuit it would be much appreciated.
Cheers
Dave
Old 19th January 2006, 06:13 PM   #9
anatech's Avatar
Hi dw887,
Some advice. Don't substitute part numbers on this. It's going to be fun, but do-able. This amp does not forgive mistakes in repair.
-Chris
Old 20th January 2006, 04:15 PM   #10
Steven's Avatar
Default 8000A
It has been posted earlier, but here it is again:
Steven
Audiolab 8000a dantzig65 Solid State 9 6th June 2011 02:48 PM
Audiolab 8000A upgrades Transworld Solid State 5 28th June 2009 12:31 AM
Help ! Audiolab 8000A PSU Caps tldik Solid State 2 14th December 2007 06:38 AM
Help! Audiolab 8000A Matthewong Solid State 9 15th October 2007 06:09 PM
audiolab 8000a davephot Solid State 35 26th November 2006 10:25 PM
Page generated in 0.09519 seconds (79.08% PHP - 20.92% MySQL) with 11 queries
