Regulator - Page 3 - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 19th January 2006, 04:45 AM   #21
The low rbb types can show negative resistance, which is why we add base stopper resistors
Old 19th January 2006, 05:58 AM   #22
Stocker is offline Stocker  United States
Originally posted by janneman
presto! oscillations ..
Jan Didden
LOL that's funny!
To get a proper regulator from that +/- 17 volts, you need 1x 78xx / 79xx series regulator IC, one or two capacitors, and maybe a resistor to obtain a non-standard voltage. < $10 if you know how to shop.
Jesus loves you.
Old 19th January 2006, 11:50 PM   #23
Default Regulator
I can't believe it. I got service manual today. They said copy centre takes acout ten days. 24 Hours ago I place my order, today I received an all original N.O.S service manual. It is really cool. It came off a real printing press! One page folds out into a 3 foot by 3 foot sheet.
IO immediately looked at the circuity in question and the voltage are 5 and -10. The other schematic shows +7.5 - 7.5 even though it is the same IC. I will try to scan tonight and maybe I can get things right with much needed and appreciated help.
Joe
Old 20th January 2006, 06:53 AM   #24
Default Regulator
I began to think I wasn't learning anything until I pulled a scanner from my junkpile and found a bad cap in it. Now I have a scanner. There are a lot of settings for scanning. I have never used one of these. What is the best scan format for B&W to place online?
Back to the synth....
I checked power distribution throughout. It all looks good. I got to my clock Oscillator. It is a TC4069UBP Hex inverter. My Hz meter says .1 kHz but I am not sure if it works properly. The OSC should provide 10kHz+/-1.
How can I test this IC?
I will try to scan and post
Old 20th January 2006, 01:45 PM   #25
pinkmouse's Avatar
Dpi depends on the resolution of the text you're scanning, 200dp is a good start, but scan in B&W, and save as GIF or PNG.
Please don't post the whole thing, or we might get into copyright issues.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 20th January 2006, 06:20 PM   #26
Nordic is offline Nordic  South Africa
Nordic's Avatar
For pencil drawings and circuit scans, lineart format should give you the smallest files...
Old 21st January 2006, 02:21 AM   #27
Default Regulator
I followed some tests last night and from my findings, the clock OSC output looked strange. I had no other choice than to go buy Oscilloscope. That's okay because I sold a friend 2 KB Electronics dual trace, a heathkit single trace and a lodestar function generator last year. He didn't need them anymore so here they are (Heathkit and 1 KB 4 sale). I am not experience with these besides playing around. I have a box of ancient amphenol BNC connectors. What can I use for cable to make probes?
Old 21st January 2006, 03:16 AM   #28
anatech is offline anatech  Canada
anatech's Avatar
Hi argonrepublic,
You need a X10 probe to keep the capacitive loading down. Just buy the probe(s) and be done with it.
The actual cable should be a flexible 52 ohm type. This is okay for a 1:1 probe.
-Chris
Old 21st January 2006, 03:50 AM   #29
Default Reg
Now that I have proper scematics, I need to move on to next phase of learning and repair.
I have attached diagram. Output of IC2, pin 8 should be 10 kHZ, -10 +10V sweep. I have an oscilloscope here have to get probes tomorrow. can I rig something up tonight to test this circuit? I have plenty of BNC connectors, Guitar cable and 75 Ohm coax.
Old 21st January 2006, 05:42 PM   #30
anatech's Avatar
Hi argonrepublic,
It is possible to build a 10:1 probe. You need low capacitance 52 ohm cable, probe, some small cap in parallel with a series resistor (~9 Meg) and a trimmer cap for the calibration. Who knows what bandwidth you will end up with.
Not worth it for one. It's only a couple days until you get a real probe, if you put one together it will most likely "lie" to you.
-Chris
HV Regulator habsrock93 Tubes / Valves 3 21st October 2008 08:15 AM
Zener regulator with "integrated" pre-regulator 00940 Power Supplies 17 22nd July 2008 06:11 PM
Lithos regulator - A new super regulator? peranders Parts 7 8th May 2008 03:01 PM
Copyright 1999-2017 diyAudio
