| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#11 |
Hi Stocker,
I was thinking the same way. I was going to wait for a picture or diagram to show what was going on. I wouldn't call a resistor reference a regulator at all. -Chris |
#12 |
I am so thankful for the help on this site. You guys probably love a challenge and would like to reverse engineer it. I don't have a camera here. I couldn't draw it because I need practice focussing. I get distracted easily and when I look at this PCB, my eyes go in to many directions. I am going to try one more time to get schematic. I would rather save your patience for other upcoming projects. I am a beginner and need alot of help. I will be back soon
Thanks |
#13 |
Know anyone with a camera phone?
"The Source" had $30 digital camera's last year. They might be enough (480 X 640, fixed focus). -Chris |
#14 | |
-David edit:/ oh yes, if you are having trouble focusing to do even this, you will have a very hard row to hoe when working DIY electronics.
Jesus loves you. |
#15 |
The focus will come. I took a 6 month break from everything. I can't believe the way my head feels after working in the studio or on repairs. I feel like my brain has been doing pushups. I have only been using my brain for about two weeks now. It's pretty mushy. On the power supply topic...
I have two rackmount power supplies. One is a behringer Mixer Power supply(transformer, caps, resistors and regulator) The Other is a very complex looking setup(Kyocera) Stuck in a Dynamix rackmount case made to look like it goes with my mixer. I am not sure which one to use. The Behringer puts out 48V Phantom, 12Vdc aux, 5Vdc aux and +/-17Vdc. It is very versatile but I wonder about the quality. When using my mixer, I get a faint hiss during silence. I wondered if that was coming from PSU. Back to the regulator. In my synth I have some ICs that require +/-7.5 Volts. My kyocera has a +/-5vdc output. Would I have a better chance of testing ICs with +/-5volts than the present +5Vdc/-11vdc? What effect does difference on positive and negative rails have on IC function. Thanks |
#16 |
Any effect, ranging from no power-on to explosion and anywhere inbetween.
Hiss from a mixer is in the mixer itself, most likely. You can add another regulator stage to take the +/-17V to the lower voltage you need. On a side note, regulated power supplies are pretty simple to put together and they can be pretty cheap with careful component sourcing.
Jesus loves you. |
#17 |
Hi Stocker,
Can't disagree with anything you've said yet. -Chris |
#18 | |
You could also add a reverse polarised diode from collector to emitter to prevent reverse breakdown if the input is shorted while the output capacitors are charged |
#19 |
Hi David,
and I thought these followers were immune to the problem. So much for my tutors. |
#20 | |
An emitter follower's output impedance rises with frequency. That makes it look like an inductor. Just add some caps and presto! oscillations .. Jan Didden
It is a capital mistake to theorise before one has data. Insensibly one begins to twist facts to suit theories, instead of theories to suit facts - Sherlock Holmes Check out Linear Audio Vol 5! |
| HV Regulator | habsrock93 | Tubes / Valves | 3 | 21st October 2008 07:15 AM |
| Zener regulator with "integrated" pre-regulator | 00940 | Power Supplies | 17 | 22nd July 2008 05:11 PM |
| Lithos regulator - A new super regulator? | peranders | Parts | 7 | 8th May 2008 02:01 PM |
