Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
What are these components?
Old 14th January 2006, 07:34 AM   #1
Mrpong is offline Mrpong  Thailand
Default What are these components?
Hello, I found some components in my preamplifier. One says "331JF". It's orange and looks like capacitors. The other one says "2A392J. This one is green and also look likes capacitors.
could you please help me encode these components? Thank a lot.
Old 14th January 2006, 07:56 AM   #2
Vivek is offline Vivek  India
Any pics possible? That would be useful.
Thank God for DIY audio.
Old 14th January 2006, 08:04 AM   #3
sbrads is offline sbrads  United Kingdom
Default Re: What are these components?
The values are probably 330pF for the orange one and 3900pF for the green. That's just based on experience rather than having found them in a catalogue or anything. With codes like these you look for 3 consecutive numbers that make sense in preferred values (e.g. E24 series) and if there's nothing on the capacitor saying what the units are (e.g. pF, uF) then the last digit of the 3 will be the number of zeros with the units being pF, so 105 would be 1uF, 224 would be 0.22uF.
The acid test though is measuring the things but most DVMs don't like small caps in circuit, even the expensive bridge I use at work can get it wrong sometimes and some caps have to lifted to get a true reading.
Old 15th January 2006, 10:18 AM   #4
Default Thank you
Wow...Thank a lot. Sorry I don't have a digital camera with me now. However, I removed the one with code "2A392J" and measured it. The meter said 4.16nF or 0.00416 uF. I think it should be 3900pF as you said. What does "2A" and "J" mean?
Old 15th January 2006, 10:33 AM   #5
davidsrsb is offline davidsrsb  Malaysia
The J suffix usually means 5% tolerance
2A prefix means 100V rating
What are these components?Hide this!Advertise here!
SAE Components Marc S Swap Meet 11 4th June 2013 08:04 PM
NCD components rootbeer Class D 4 15th March 2009 05:09 PM
where to buy components dayking79 Solid State 4 6th February 2009 07:46 PM
components Swanic Parts 0 11th November 2004 10:00 AM
amp and components for a 911? jbrinkely Car Audio 2 23rd September 2004 01:18 PM
