Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 14th January 2006, 12:44 AM   #1
hotscot is offline hotscot  Scotland
Default Damaged Bridge Rectifier
The fuse on my Marantz amp has been blowing. (Just to test I tried new fuses a couple of times.)
I looked at the PCB and there's a big crack on the surface of the Bridge Rectifier. I've attached a jpeg of the circuit.
If the Bridge Rectifier is damaged would/could that be the reason for the blowing fuse?
Alan
Old 14th January 2006, 12:56 AM   #2
SY's Avatar
Yes indeed, and it may also have taken out the electrolytic capacitors that come right after.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 14th January 2006, 12:59 AM   #3
Default Yes indeed
Yes..the electrolytics were indeed damaged and I have replacements. I'm hoping that nothing further down the line will be damaged. it's just a pet project though.
Alan
Old 15th January 2006, 10:20 AM   #4
d3imlay is offline d3imlay  United States
The bridge failed after the electrolytics failed. The bridge may have survived the first blown fuse. But subsequent fuse replacements would blast the bridge.
Old 15th January 2006, 10:25 AM   #5
Giaime is offline Giaime  Italy
Giaime's Avatar
Send a message via MSN to Giaime
If the amp burns a fuse, prior to putting a new fuse I always check power supply components (especially in tube amps). I've learned this the hard way
Don't replace a burned fuse with a new one just to see if the fuse keeps burning.
Old 15th January 2006, 11:28 AM   #6
I would worry about the transformer, if the internal thermal fuse goes you are in trouble, the bridge and ecaps are easy enough to replace.
Always remember that semiconductors usually fail short.
Old 15th January 2006, 05:35 PM   #7
Default I replaced the bridge..
The fuse no longer blows.
Now the remote works to control the volume.
I don't mean I hear it, I'm still getting no output from the amp but the rotary control moves via the remote.
So..power is going into the main pcb, it's also leaving the main pcb via leads, to supply the remote pcb and the volume pot pcb.
It's been suggested to me that the reason I'm getting no output tp speakers or headphone is because a relay has failed or some kind of protector.
I have the schematic if anyone wants to look.
Alan
Old 15th January 2006, 06:17 PM   #8
Default Re: I replaced the bridge..
I would suggest the most likely cause is that the power amp has failed, resulting in a standing DC voltage on the output - the protection circuits will keep the relay turned off to protect your speakers.
The power amp failing could also easily have killed the bridge rectifier - presumably the emitter resistors will have gone O/C now, which is why it's not blowing the fuse?.
Nigel Goodwin
Old 15th January 2006, 06:56 PM   #9
Default Can I test...
Can I test the power amp using a meter?
(I'm knew to this but I obtained a meter yesterday and have checked the fusable resistors)
I'd appreciate knowing how to check a poweramp and to test for standing DC.
Alan
Old 15th January 2006, 07:40 PM   #10
You simply measure the voltage at it's output (the amplifier side of the relay). Often the easiest place is the emitter resistors, they are usually obvious and easy to get to. The voltage should be zero, or very close to it.
Nigel Goodwin
Bridge rectifier vs Full wave rectifier hilbert_mostert Tubes / Valves 4 28th April 2009 08:26 PM
4 rfb-02 rectifier bridge pcb's BeerCan Swap Meet 1 23rd July 2008 07:07 PM
Integrated Rectifier Bridge VS Rectifier Diodes Sci Chip Amps 11 16th July 2004 02:43 PM
Bridge Rectifier thylantyr Solid State 2 21st August 2003 09:11 PM
Page generated in 0.10319 seconds (81.95% PHP - 18.05% MySQL) with 11 queries
