| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
any one can help me in finding PFET OR NFET to work as aswitch . the control signals is output of FPGA and the FET prefer to have overtemp or over current protection . the rating is 100vmax (30vtypical) , load current max 50A load ( protection 30-40).
thanks for any help |
#2 |
Electrons are yellow and more is better!
Check www.infineon.com which has loads of high-side and low-side switches up to 100 A or so.
/Per-Anders (my first name) or P-A as my friends call me |
#3 |
I use International Rectifiers IPS 511 with good resuslts, but that is only 5A...
there is IPS0151 rated for 35 A. There is also the BTS series from Infineon, which looks good for logic control, but I haven't used them.. slightly higher current than I need. BTS 555 is a high current version. Google for "Smart power switch".... also decide if you want high or low side switching... |
#4 |
We use BTS660 which is pretty nice and you have also BTS550 for lower voltages. Remember you can put those switches in parallel in order to get more current.
| P channel Mosfet switch schematic | bart_dood | Everything Else | 2 | 18th March 2009 07:53 PM |
| MOSFET switch used as ON-OFF Delay timer | lineup | Solid State | 4 | 10th August 2008 06:44 AM |
| Never try to switch 450V DC at 3A with a conventional mains switch... | Eva | Power Supplies | 28 | 1st November 2006 09:24 AM |
| Main on/off switch for amp using a piezo switch | using_e | Solid State | 13 | 20th June 2006 05:55 PM |
| Using a momentary switch for main power switch? | FullThrottleRic | Parts | 9 | 25th June 2002 08:23 PM |
| Page generated in 0.07532 seconds (70.64% PHP - 29.36% MySQL) with 10 queries |
