Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 10th January 2006, 09:32 PM   #1
Default Alps switch for stepped attenuator
hi.
Has anyone used the alps 4 pole 23 position switch for a stepped atenuator?
I just got 2 of them from triode electronics, I also have the resistors... now I want to build it but I canīt figure out the switch.
I am not able to switch it, and it came with no spec sheet or anything.
Help please!!
Old 11th January 2006, 05:53 PM   #2
Nobody??
Old 12th January 2006, 10:43 PM   #3
cetoole is offline cetoole  United States
Check out this thread, its been a while since I read it, but there should be some info in there you can use.
Old 12th January 2006, 10:58 PM   #4
cetoole...
thanks for the link....
actually I was able to figure out how the swith works, one problem is that is very hard to turn but was able to do it and I will start soldering resistors soon...
It will be easier once it has a knob.
thanks!
help identifying an Alps stepped attenuator jscherer Parts 1 15th February 2009 06:01 PM
Switch for stepped attenuator jnb Parts 0 4th October 2007 02:02 PM
what other resistor to use for a diy stepped attenuator (using grayhill/elma/alps sw jarthel Parts 0 21st June 2006 12:40 PM
Alps Stepped Attenuator ultrachrome Parts 13 4th November 2004 08:45 AM
DCT Stepped Attenuator Switch 30 Step mozfet Swap Meet 29 1st March 2004 05:02 PM
Page generated in 0.06878 seconds (67.13% PHP - 32.87% MySQL) with 11 queries
Copyright Đ1999-2012 diyAudio
